2019 ram new bodystyle
jantonio
Having issues clearing code for accuator, i have change it twice an still keeps coming back does anyone know what needs to be done to fix this problem? Because i cant even remote start my truck. Please help
What is an accuator? You need to clarify that, for an answer.
Riadotor accuator that opens and closes shutters.
did you remove anything?
did you buy used and someone removed something?
Power, ground, lin bus.... are all those circuits good? Next check your active air dam.
You spelled it wrong, and didn't even give context, in the original post. Cbty2050, is a mechanic. his suggestions will be best.
Having issues clearing code for accuator, i have change it twice a still keeps coming back does anyone know what needs to be done to fix this problem? Because i cant even remote start my truck. Please help
It could be your active air dam. The disconnecting it and clearing the code
