Camshaft Replacement at 60k miles...
PanzerFreak
Just wanted to share what happened with my 2019 RAM 1500 Bighorn (3.6L with e-torque). For about a month I noticed a very slight ticking noise that became more frequent as the vehicle increased in speed. The dealer initially thought "it's likely exhaust related bolts". I took the truck in just below 60,000 miles while under the original factory warranty (also covered until 100,000 miles or nearly the end of 2026 with a certified preowned warranty).
Long story short short the dealer reported "The right intake cam was worn causing damage to right exhaust cam", tech notes also said "removed the right valve cover and found intake cam wore out and exhaust cam lobes scratched up". The list of service and parts replaced replaced is rather extensive (the right cams, intake rockers, phasers, vvl sensor, and much more). This had to be $2,000 - $4,000 in parts and labor I take it from a dealer?
Thankfully everything was covered under warranty but it does make me nervous how the vehicle will perform long term. The oil was replaced again during this service and I plan to replace it in 3,000 miles, a bit early, and have an oil analysis done. The engine ticking is not only gone but the entire vehicle just seems drives smoother with this work done.
An early oil change is a great idea to get any break in material from the new parts out of there, and stick to a good interval of oil changes. So long as your oil filter was doing its job and caught all the metal from the dead cam I wouldn't be too worried. That having been said I'm not familiar with the oiling system on the pentastar but that metal-laden oil all should've just gone straight down to the pan after the cams and either stopped by the pickup screen or the oil filter. Sure some could've run through the internals and maybe caused damage, but I imagine the oil analysis will give you a better idea of any wear that is occurring/has occurred. I would definitely keep an eye on your oil pressure for the next little while and your ears open for any other ticks or knocks (or for the life of the vehicle, if you like to keep an eye on things.) And at least you have 40k more miles of CPO warranty to make a decision, keep the truck that had some significant engine surgery, or wash your hands of it and trade it. either way, best of luck to you and your truck!
Thank you for the reply and tips! The truck has been driving great, better than ever, since the cam work was done. I hope it stays that way, would like to keep it long term. I’ll post the oil analysis results here when I get it done within the next few months.
Follow up on this issue. So just 5,000 miles later at 65,000 miles the ticking sound returned. Brought it back to the dealer and they said it was the same side again, all right camshafts replaced again. This time they said the oil cooler had some metal shavings in it plus was leaking and needed to be replaced.
I was surprised when they said the left side camshafts are fine. Why would the right side fail once at 60,000 and then again just 5,000 miles later at 65,000? I did notice a slight bit of oil leaking onto my drive way over the past couple of months, probably the oil cooler issue.
Thankfully everything was covered under the certified preowned warranty. However, I’m now doubting the long term reliability of this truck.
How’s the truck doing today? I just sent my same truck in for the same exact problem. Was making a ticking noise and they tried to play it off for normal engine noise. I told them to wait till the morning when it was cold to start it. Same issue, intake camshaft. I’m unlucky however because they’re on back order apparently. No ETA when it’ll come in.
Do you have a status update on your truck? I have the sane issue..took it in April 28..
Very similar issues to what I am currently having with my '19 BigHorn 3.6L. I'm at 102k miles and Stellantis/RAMCARES customer care team seems unwilling to offer any assistance. Won't even help with a loaner vehicle or rental reimbursement, and there is no ETA on when parts might be available for repair (lifters and camshafts). Personally I believe repairing just these parts is not worth the long term risk, and problems are highly likely to recur.
Do you have a status update on your truck? I have the sane issue..took it in April 28, 2025..
+1 on the intake cam issue. Unfortunately I'm at 6 years and 63,000 miles so no warranty coverage. $2,100 dollar repair. This truck has had the front differentials replaced and now this. All under 65,000 miles and within the last year. I have to admit that I didn't expect this kind of drive-train trouble under 100,000 miles. It's also making me consider if it's worth keeping or if I should make the switch. Kind of disappointed in Ram. I had switched to it from a 14 year old Tacoma. Maybe the quality of the Toyota gave me a false sense of what to expect from a drive-train.
As far the backorder on parts, the dealer said it would be 10 days but called the next day and said that they were able to source them another way and that my truck would be done in a day or two.
Its a super common failure in the Jeep world. I just replaced 3 of my cams and 4 other people I work with had to replace their right intake cam.
Mine is “in line”. When a loaner car is ready, my local dealer will perform the repairs. I am not sure of the extent of damage right now. I’ll try to remember to report back when this is resolved.
Ok, I got my truck back. The following was copied verbatim from my invoice (some of it redundant):
"Passenger side intake cam had a high lift lobe completely worn down. Metal shavings in cylinder head. Found one of the high lift lobes on the intake passenger camshaft had worn down causing the rocker and lifter to go bad which was the cause of the noise. Replaced right side intake camshaft with the 6 correlating lifters and 6 correlating rockers. Installed new valve cover gasket, 3 new spark plug tube seals, and both front cam phaser gaskets. Installed valve cover back onto vehicle, performed an oil change, and performed the cam/crank relearn procedure in witech. Test drove vehicle to ensure proper operation and that the noise went away."
All of these repairs were covered under warranty, no cost to me. Truck is super quiet, and as PanzerFreak stated, the whole truck just seems to run better. I'll be keeping a close watch on the truck for repeat issues.
Oh - importantly, my truck has 35,158 miles on it.
