Help on How to Remove This Covers.
Paramedic835
Good day to all,
First time poster so sorry if I post in the wrong section. My question would be how to remove this two panels ? Any screws that I should be aware of or any wiring I should not mess with ? BTW, it is a 2021 Ram Classic. Thanks in advance.
Jose
First one under the steering wheel there are screws below it in the footwell (you can see them in the pic). Then it should pop out if I remember right. The second one you may have to take the radio stack out, but I only have the 12" radio so I'm not sure.
Thanks. I suspected I would have to take our the radio to get it out. Vehicle is going to be used as a first response vehicle for a volunteer fire department and I have to install the lights and siren and it is easier if I can remove those to route the wires more easy and cleanly.
Radio is super easy to remove, I believe just the two torx screws at the top and then you simply pull towards you. Mind the wires as you pull away, several you will need to disconnect.
