Can 35 inch tire for 2021 Ram 1500 4x4 that has 2 inch level?
Blackbird345
Thinking about purchasing 35 inch tires for 2021 with 2 inch level. Anyone know if a 35 inch tire can fit?
Thanks
Probably going to depend on a little more info…OEM vs aftermarket wheels, width of the tire, etc. but my 285/65/R20 KO2’s fit on my stock Laramie with off-road package and OEM wheels. Have zero issues now that I’ve added the Cali-Commuter to the equation. Hope that helps.
It'll be on stock 20 inch rim. I'm wondering if the truck has an off road package because it's pretty high.
Offroad package will come with a one inch lift stock from factory, some additional skid plates, a locking rear differential and some other odd ball things if that helps you in your research.
Thanks! Would the original sticker state that it has Offroad package?
It should. I think it’s actually listed as off-road group, but I’m not 100%. Should also have the 4x4 off-road sticker on the bed unless the original owner/dealer removed it. Here’s mine for example.
If it's an off road package there will be a locker button for the rear diff near the shifter. Did you buy used? It could have an aftermarket lift
