2025 3.0L I6 K&N Performance Air Intake System
bshelton8
5thGenRams Supporter
I wanted to review the K&N Performance Air Intake System I purchased for my 2025 Ram 1500 Limited with 3.0L HO I6. I want to start by giving a shout out to K&N. They have always made good products at affordable pricing. They also support the military and will give you a 30% discount if you call them directly and place the order.
I called K&N last month to talk with them about the new air intake and to try and get an idea when they would be available. They told me early December and to just keep checking the website for updates. I have been checking daily for stock on their website and last Monday they finally got some. They weren't around long and still show out of stock on their website.
I ordered mine on Monday and had it by Thursday. I had some time on Saturday to install. The install was pretty straight forward but you could tell this was an early release.
1. Instructions are good but could use a little more detail. Such as socket size used on the actual step. Socket sizes are listed on the tools needed section but not on the actual steps in the Instructions.
2. The same goes for allen and torx sizes.
3. The K&N air filter box is tricky to line up and get into position. The hood strut is in the way and causes you to have to come in at an angle and makes alignment tricky. My first attempt had enough of an angle that the mounting grommets all pushed out.
4. The fit and finish was a little rough on the one I received. I totally understand they were rushing to get to market and I am just happy to have one. Rough edges around the air box cut outs are one example.
5. Step 12 in the Instructions is installing the mass air sensor mounting adaptor. They state to orient like their picture. Picture is black on black and almost impossible to pick up the correct orientation. Mainly because the adaptor is almost identical in either orientation. Needless to say, I got it wrong the first time but figured it out on step 14 when installing the mass air sensor.
6. My kit was missing one of the lock washers used on the adaptor plate. No big deal, I have plenty.
7. I was disappointed by the lack of engineering on securing the coolant bypass line and wiring harness for the mass air sensor. The factory air intake tube has 2 holders for the coolant bypass line and like 5 holders for the mass air sensor wiring harness. The K&N air intake tube has a make shift bolted on bracket with 1 wire tie to secure the coolant bypass tube and zero brackets for the mass air sensor wiring harness. You have to play with the orientation of the K&N air intake tube to get the bolted on bracket in the right position to secure the coolant bypass line without putting it in a bind. I just tied up the mass air sensor wiring harness the best I could with wire ties. Not a fan of leaving it hanging loose.
8. The black #88 hose clamp, item O in the parts list, was the wrong size and didn't have enough grooves to tighten down the air intake tube to the air filter. Luckily I had one laying around that worked. The other gripe I have is that the black #88 hose clamp is never mentioned in the Instructions. It should be in step 16 but never mentioned. You can see it in the picture, just no mention. The air filter is just wedged into the air box which had me concerned from the beginning. I originally thought the black #88 hose clamp would be used to somehow secure the air filter to the air box in step 11 but it wasn't. I really don't like the air filter not being secured to the air box!
I along with others was hoping the new K&N air intake system would enhance the sound of the engine especially with the open air box design. I didn't notice any real difference in the sound while driving.
The extra 41 horsepower is nice but so far not really noticeable while driving. Not that I expected to feel a big gain.
Overall, I am happy I made the purchase and happy with K&N for getting the product to market in such a short time. Most of my issues/concerns I still chalk up to early/first run issues and expect them to only get better over time.
Here is a link to the K&N website
20241208_224756.jpg20241207_131937.jpg20241207_132129.jpg20241207_143949.jpg20241207_145148.jpg
I would love to see another independent dyno run. 41 seems crazy.
Thanks for sharing the dyno graphs! I agree but it seems like with the I6 HO or SO, small changes make a big difference. The JB4 piggyback tuner claims to add 104 HP. JB4 posts a graph from the Jeep Wagoneer with the same engine and claims similar results on the 2025 Ram 1500. Crazy gains claimed on the Hurricane across the board.
View attachment Jeep-Wagoneer-dyno-horspower-jb4-tune-specs-price_1024x1024.webp
View attachment 193714View attachment 193715View attachment 193716View attachment 193717View attachment 193718
How's it holding up so far? still liking it? no issues? thanks.
NO "cold air intake" kit is going to add that much power unless tuning goes along with it. That's too much of a change in airflow for the stock tune to deal with. The MAF sensor is going to freak out. I'm calling shenanigans on that. Either that kit isn't really making the power advertised, or it's getting those numbers because it's running the engine lean. Either way is bad news.
Secondly, K&N filters trap dirt about the same as a screen door. You might as well just delete the filter and save money. I keep thinking about the Project Farm video on YouTube where he used a particle counter to test different brands of filters, and the K&N allowed exponentially more contaminate to pass through versus any of the standard replacement filters. Not good for an engine long term, that's for certain.
So far so good, no complaints.
thank you for the update! little bummed it didn't increase the turbo noises but I guess like somebody else mentioned on another thread has to do with location of the BOV or type ram used... I was hoping it was gonna get loud like my EVO IX was when I added just an intake haha...
As much as we all want a fix, there is just no replacing the sound of a Hemi V8! I really miss that head turning rumble.
agreed. but I definitely love the sound of a turbo over the constant whine of my trx supercharger it just gives me a headache over time haha. but of course I think we can all agree a v8 sounds great no matter. but man this turbo 6 is smooth.
How are you liking it still? I'm wondering why they went with an open top design, there's no air being vented that way from the hood.
Did RAM switch to a MAF system on the hurricane engines? Genuinely asking. Because they have never used MAF on any other engine.
So I just ordered the k&n filter for my SST. Did they have you disconnect the battery for half hour to "reset the calibration" on the air sensor. Cause of you did I'm curious how you did that if the truck has the start/stop feature
I disconnected both batteries during install. I didn't time it but I am sure it was at least 30 minutes.
K&N graph states 5th gear runs.
6th gear on a 2025 is 1:1 gear ratio.
5th gear is 1:29
I’d like to see an independent dyno run in 6th gear.
I'm curious about the JB4 as well. I know Diablo was working on tuning for the standard output claiming 50-60 who gains.
How are you liking the JB4 and K&n? Isthmus your daily driver? any issues and do you usually just leave it on map 1? thanks.
It's not my daily driver. I normally keep it on Map 0 to help with gas mileage. The speed limiter is a major bummer. Even with all the horsepower, you can't even step up when someone challenges you on the interstate. You just wave and say not today.
