2025 Battery Issues
Savasage
Hey everyone - Not really looking for a solution here, but more curious if anyone has had similar issues, and if they were ever resolved.
I recently traded in my 2500 Ram Power Wagon (2022) that I loved and never had a single issue with, but having owned a 1500 previously, I had been looking to go back for the better gas mileage and a more reasonable size for someone living in a city.
The first morning after purchasing my truck, I woke up to a dead battery. I had it replaced by the dealership and chalked it up to a truck that had been sitting on the lot for too long. All was good until a month later when I the battery died again. This was the Friday after Thanksgiving, so I was stuck with a dead battery until the dealership opened back up on Monday. On Friday/Saturday, I jumped the battery and was able to take multiple trips throughout the day with the truck being off for about 5 hours between drives. On Sunday, I jumped the truck to run to the store. In the time I was in the store, the battery died and I had to jump the truck in the parking lot. One interesting thing I noticed is that the lock/unlock feature did not work since the first time the battery died on friday. Even while driving, the doors wouldn't lock/unlock electronically.
The big issues start on Monday. I go to jump the truck and take it to the dealership, and the truck will not start. I attempted to jump it from my Noco 1750A (battery is only 800CCA), my girlfriends sedan, and a city truck (F250) that saw my struggling and stopped to help. At this point, my shifter knob is just floating and free spinning between P/N/R/D.
At this point, I call a tow truck and have the truck taken to the dealership. The dealership is claiming they are hooking it up to a diagnostic machine that can take "up to 6 hours"...
I am waiting to hear back currently and see how big of an issue it is, but I was wondering if anyone else has had similar issues on a 2025 1500. I see numerous post talking about phantom drain, but no one has mentioned issues that stem this far.
Have they checked the secondary small battery? I had to replace mine the day after purchase
Yes - This is something I failed to mention in my original post. They replaced the main battery and the secondary battery the first day after purchase for me as well.
We have virtually all our CDJR with dead batteries every couple days
Actually just had this happen. They claimed the main fuse for the truck was blown, and only could be blown from hooking jumper cables/jump boxes up incorrectly. They replaced main fuse and both batteries, claiming both batteries were below 20% life.
my 2022 was towed 3 times for dead battery and could not boost it to save my life. 2 times they said it was bad battery (first and 3rd time) second time they said all everything needed programming updates as part of TSB.
In the end I figured out on the 2022 the top dash 12v was not turning off with the key and my detector was running. Apparently if you run the battery below 10V or something the truck is fubar and throws codes all over the place when you try to start it (not knowing the battery is low). then battery booster literally go from 100-0% in seconds ( I've seen it with 2 of them brand new). Booting with another vehicle doesn't work then.
I've pulled the fuse panel and moved the fuse so the 12v now runs off ignition and it hasn't happened again.
However, I fully expect the next time my battery gets low for any reason, I'll be having it towed to be reprogrammed again...sigh.
We just bought a 2025 RAM 1500 Limited, 600miles. Same problem with battery dying. At dealer since Thursday PM. They were able to tell there is a drain, but can't find it, working with engineers/manufacturer. Did any of you get resolution to your battery draining? Or was it a problem with charging system?
I'm having the same problem with my 2025 1500. Every 2-3 month my battery is dead and have to jump it. Dealership can't find any cause.
We purchased the vehicle from the CDJR dealership on 29 Oct 2024 and have experienced numerous issues since then.
On the evening of 29 Oct 2024, the truck would not start due to a dead battery. We contacted the dealership, and they came to our house on the morning of 30 Oct 2024, left a rental and took the truck. They determined the battery simply needed charging. We were not told that they ran any advanced diagnostics. They returned the truck to us on 1 Nov 2024.
Ten weeks later, on 14 Jan 2025, the truck again would not start. We contacted the dealership, and they came to our house on 14 Jan 2025, left a rental and took the truck. They explained that they were able to recreate the drain on the battery and correct the issue.
Several weeks later on 3 Feb 2025, the truck again would not start. We contacted the dealership, and jump started the truck and took it to the dealership. They again gave us a rental. This time they told us that they were going to have a RAM engineer visit the dealership and evaluate the truck. The engineer determined that a faulty catalytic converter caused a parasitic drain on the batteries. After two months of delays due to back ordered parts and broken parts we returned the rental and picked up the truck on 1 Apr 2025.
Finally, on 29 May 2025, the truck's battery died again. We were in Wytheville, VA and the local Dodge dealer determined the auxiliary battery was the cause of the drain on the main battery and replaced it for free.
Our lawyer sent them a letter to try and energize them.
Since then, the truck dies quite frequently has gone a total of 3 consecutive days without needing a jump. Originally, the main and aux batteries were both dead and the remote wouldn't work. After the aux battery was replaced that remote always works, the lights come on and the running boards deploy on approach. That tells me that our dealership never figured out that the aux battery was defective, either physically or its connection.
We dropped it off at the dealership today and they are going to do "diagnostics". They called me later in the morning and asked if the battery drain only happening when it is raining. It does not...
I'm new to the forum and didn't reply to you when I posted, but you can see my post from today about my issue.
Having the same issues. Battery will drain until nothing left and you have to jump it to start. It's been to the dealer where I bought 4 times and they haven't been able to fix the problem. They've replaced batteries, fuses, sensors, etc... but to no avail. The first time I brought it in was because the auto stop/start was not working. They told me it will not turn on when there's a load on the battery such as from the heated seats & steering wheel. So I monitored the battery charging message. It was always on regardless on load. Eventually, the battery went dead and I had to jump it to start each time. After the forth time at the original dealer, I brought it to another RAM dealer. When they measured the battery capacity, it was down to 43%. They changed some more sensors but it has not fixed the problem.
Did this issue ever get fixed? I am having the same issue on my 2025 1500. So far, three sets of batteries and 4 calls for assistance. Could not jump it with a battery pack and one time it blew a main fuse and went into limp mode.
We're sorry to hear that both of you are facing concerns @Flynbanjo @Huntman65. Our team has reached out to you both individually for potential support. When able, please follow up with us for assistance. Thank you and we hope to hear from you soon.
Chris,
Ram Cares
Unfortunately, yes. Same issue for me. My truck was custom ordered and delivered to my home in February and has only 3K miles on it. It has left me stranded 2x so far and to the point keyfob doesn't even work. Had 2 jump-starters and they still would not charge enough to start. I Had to trickle charge for hours to drive to dealer. They have had my truck for a month now with 2 other trucks doing the same thing. Supposedly troubleshooting 1 of them to fix the others by proxy. Really love the truck, and such a PITA to have to deal with these kinds of issues on the new Atlantis architecture. I waited an extra year to pull the trigger on the purchase in hopes that issues like this would have been resolved. I already have a RAM Cares case, but still no ETA on what the fix might be. Dealership for now is leaning towards auxillary cooler for the turbo as the issue. Each time this has happened, it drains my 12V battery to 0 in less than 3 minutes.
Yup. Mines dead today with 3k miles. There have been so many problems with this truck Ordered it special. It’s turned out to be a complete piece of crap.
Although it seems a lot of people of this issue but not everyone, could it be one specific feature within the truck that is draining the battery.
Something like auto-step boards, heads up display, ....
battery didn't drain overnight ever before, power boards have been on for two months now. nothing else changed. The battery was fine the day before, started right up. Next day its dead.
My truck was fine from February through June. I don't have step boards, but do have a HUD. Dealer had my truck for 30 days and could not replicate the issue to troubleshoot, so it isn't resolved. I'm sure it will happen now that I drove it home. STAR had them turn off the approach lights and was told to unplug my USB drive for music (LOL). I don't think HUD, USB, Radar, Boards or dashcam is going to drain a full battery to ZERO in < 3 mins.
Agreed
Looks like this is a trend. The wrecker just left with my 2025 Ram 1500 Laramie for the 3rd time with dead batteries. Similar stories above just adding notes to follow the thread. Good Luck everyone.
  • Jako
