A couple of questions regarding adding ACC to my truck.
Jonnysdad
I've read through most of the thread on adding the ACC and the other options, but I still have a couple of questions.
I have a 2022 Laramie with front collision warning and braking, rain sensing wipers and blind spot monitoring. I believe the only hard parts I need to add to get ACC is the correct ABM module and pump and the correct buttons on the steering wheel. Correct?
Is there a need to take it to the dealer to get it calibrated, or will I be able to use the ACC right after enabling it with ALPHAOBD?
These are the pieces I ordered. Is this what I need to do the programing?
Thanks
Thanks
Why didn't you post in the thread where people can better answer you instead of making a whole new one?
The post in the ACC thread is pretty clear on everything needed.
No need for calibration and yes, you can use it right after as long as you have no issues with ABS initialization.
Everything you ordered should work.
Again, everything is in that thread and questions should be asked in there.
Thank you Vincent. I will make sure you post my questions in that thread going forward.
