New Uconnect firmware 31.42
I think Jimmy said your radio was a trial version that you can't upgrade to a newer version
Yes so my module was a trial. I got one locally here for 150 off a wrecked car he sold the screen but not module. I pulled the module and it works just android auto isn't full-screen. And when I first connected the module it wouldn't read anything from my truck battery reset didn't do a thing. I plugged USB with update and it updated and pulled all the info from my bcm and works perfect.
Maybe I'm late to the game, but I've looked quite a bit with little results in finding updates to my 19' Limited. I'm posting a screen shot of my 12" unconnect screen so that someone might point me in the right direction. Sorry for hijacking anyones posts. I have not been able to update the system with any available files I've found.
Unfortunely, you have UConnnect 4 and this update is for UConnect 5. Not sure what is the latest version for UC4
Thanks for your reply, that's why I posted here, was hoping someone "in the know" might possibly direct me to the correct thread, I've tried searching, but results are few.
I’ve seen this before, and it’s probably a radio module that was used for testing. I doubt your radio will take a production update, but you can try. This is the latest:
16gb USB stick format to fat32. Do not unzip or extract anything, just put the whole zipped folder onto the usb stick and plug it in.
My guess is it’s going to say software not compatible with vehicle.
@Jimmy07 will this update work on a 2022 RAM 2500 Tradesman Crew Cab with a Uconnect 5 with 8.4–Inch Touch Screen Display running Uconnect version: FCA_R1L_ARM64_00.145.00.15.00
In case it matters, I’m in the United States. Thanks!
This is technically not a software update for 2022-2024 UC5 radio part numbers. It is the software that comes on 2025 UC5 radio modules. It might work on 2022-2024 radios, and I have it on the 2025 radio module installed in my 2019, but there’s no full screen android auto (and there never will be on a UC5 radio).
What has changed on the 2025 radio module that it is running different software?
Anyone install this on a US radio?
Sent from my SM-S931U1 using Tapatalk
I try but after insert pendrive nothing is happening. I am from Polish but my RAM is from Canadian not from EU importer so i can't do OTA update from WIFI. My radio have FCA-MY23.T25.48-PROD.
EDIT: I update to FCA-MY23.T27.46-PROD. (I use must use fat32 pendrive and copy zip not unpack position on run and insert stick to first usb after i must radio reboot 10s click volume button and insert to port 1 next insert to port 2 and promp update was show so i can do update to FCA-MY23.T27.46-PROD update took 10 min. In my RAM this fix some bugs on radio - lags on start, turn off after i click off button engine befor update radio play for 30s to 60s after close car) EU firmware no promp for update.
Curious if anyone knows....
On 01/30/24 my 12"/U5 OTA'd to "..MY23.T27.46" and just yesterday it forced an OTA to "..MY24.U29.44"
Can't tell any difference..and Thank God, no issues that I can tell either!
Anyone know if this is most current updated? What is updated? TIA
I have a 2020 DT will a 2025 module and screen work? I have alfaobd but haven't look to see if I could select 2025.
The module will work but only if you configure it to powernet but the screen will not turn on you will need a 22-24
So, does anyone has a change log of bugs they fixed or features they added on this 31 version?
When I will bring in the car for maintenance, I will ask the dealer to check for a new version update.
