It's not replaceable. You might be able to fix it if you have the skills in electronics.Noticed a couple of days ago that lower end of the day light running lights on the driver headlight is not working.
Is this something that can be fixed easily?![]()
I could try. Is there any videos or other tutorials available for that?It's not replaceable. You might be able to fix it is you have the skills in electronics.
No, you would need to probably repair the electronics board. There is an aftermarket solution that replaces those with RGB style LEDs.I could try. Is there any videos or other tutorials available for that?
