TRX wheels/OE TRX tires on 2022 Limited
Humer91
I know there have been threads on this but no real conclusions have been posted. If I use 1.5 inch spacers will the 325/65r18s fit within the UCAs? I know i will likely have some rub in the wheel well at full turn (maybe) and that's ok, i can live with that, but UCA rub is a definite no-go.
I have a 2019 Laramie and got TRX wheels and tire takes offs, have a 2.5" lift in the front and only 0.25" wheel spacers and there's no rub on the tire on upper control arm. My upper arms are the Mopar lift ones that are the same size as stock.
With that size spacer you will clear UCA. 100%
Yes, as said, you can clear the UCAs with just a 1/4" wheel spacer. With 1.5" spacers you'll clear just fine. But you'll have rubbing elsewhere within the wheel well.
are those wheels different from all other after market 18" wheels? I have a 2022 limited, and last summer I wanted to switch out of the 22" wheels to 18's.
At discount tire, we tried many wheels, and they all rubbed on the brake caliper in the front. not just rubbed, but it actually scratched the wheel.
So the manager called the Fuel reps and they confirmed they didn't have any 18" wheels that fit the limited. I gave up and got 20" wheels.
What about using OEM Rebel 18" wheels?
The dumb a** that helped you at discount didn’t know what they were talking about and apparently the fuel rep didn’t either. U can go to customoffsets and see a gallery of 5th gen’s with 18’s (w/fuels)
Link to said gallery….
