FastBlackRam
- Aug 26, 2019
So here are pictures of my RF Hub that is getting replaced due to water intrusion via a back window trim crack/leak.
My question is why not seal the new one with a bead of silicone or the like to prevent water from ever getting in the new one? I am replacing the window but in case the new window leaks. Now that won't prevent water from getting into the connecting cables which are also being replaced. Unless you guys can recommend how to seal up an electrical connector. The case just easily pops apart so it looks like that might work as a preventative measure. FYI the new window being done by Safelite comes with a lifetime warranty on defects and leaks. Also covers consequential damage if it does leak (like the RF Hub). FYI the hub is covered by auto insurance, but not the window. The window replacement cost is $930 by Safelite.
Also when they are done with it if I disconnect the connectors and take it out to do the seal job will it just continue to work after I reconnect it?
What do you guys think?
