Lasfit led switchback turn signal as DRL using Alphaobd
Adamsl04
I have a 2020 Ram 1500 DT Bighorn with base lights. I have lasfit led switchbacks in the front turn signals and they work fine until I change the DRL location to turn signals then I get fast flash and warning saying turnsignals are out.
Has anyone used alphaobd to get the lasfit led switchbacks to work as the DRLs and what settings did you change to get them to work?
I tried led front turn signals as present but that didn't help.
Did you change all the settings in AlfaOBD to tell the BCM that you have LED's installed. There are about 8 or 10 settings you need to change. Just search LED in alfaOBD and change all settings to yes.
Will give this a shot.
