Well the tires and wheels alone will skew the numbers on the Hemi. Also, were these done back to back. Temp and humidity differences will mess with numbers as well.
No doubt the Hurricane will be a beast of a motor, especially when tuned; but stock for stock those numbers look a little inflated IMO. I love the red and black look on that 25 though. Sexy.
I test drove a 2025 with the SO the other day and it felt a lot stronger merging on the highway. Compared to my laramie 5.7. Sales dude said step on it lol felt good. Makes me wanna drive the HOWhy do you think they are inflated? The difference is about the same as the factory reported HP numbers for the HO Hurricane vs Hemi and not much different than what they report for the standard Hurricane. All the reviews I've read about the Hurricane engine is that there is very noticeably more HP than the Hemi and it takes more than a few HP to make a difference most drivers will notice.
It's no doubt stronger, but not night and day. The HO on the other hand. Yes please.I test drove a 2025 with the SO the other day and it felt a lot stronger merging on the highway. Compared to my laramie 5.7. Sales dude said step on it lol felt good. Makes me wanna drive the HO
Agreed, especially considering it's transferred through the same drivetrain. Gear ratios will also throw off numbers as well. I dynod my supercharged mustang a few different times over the years with tire/gear ratio changes, and got quite different results. Most dynos can be manipulated fairly easily when playing around with correction factors.The Hemi had 17.4% parasitic loss seems high and the Hurricane had 11.1% which seems low.
Of course, he was used to the 6.7 Cummins which while powerful, wasn't winning any street races.
All else being equal, the 6.7 Cummins will blow away a 5.7 Hemi in every kind of contest.
The hemi has always been doggie imo. It really benefits from a tune.
Even a pulsar on tow mode wakes this truck up a fair amount. It's not necessarily the engine itself, on stock tune they have kind of gutted the mid range throttle response, probably for fuel efficiency.
Lol. Except 0 to 60 from a dead stop with nothing in the truck. 8.4 seconds.
Why do you even bother posting, because literally every post of yours I have the unfortunate luck to stumble across is half truths or complete bull ****.
LOL. It's actually your post that is the half truth since the article did not compare the exact same HD truck with a 5.7. As I said in my post you quoted, with "all else being equal". Things like different gearing, weight and aerodynamics will have a huge impact on 0-60 performance and the typical 2500 weighs about 1500 lbs more than the typical 1500. Do a little research into how much even 50 lbs will impact 0-60 performance and you will be shocked. THINK HARDER.
The weight diffrence is a lot more than that. My 21 ram 2500 with the 6.7 was 8430lbs with me in it . My 25 1500 warlock 3.0 is 5220lbs with me in it. Both crew cab 4x4 short beds. Most stock SO 6.7 dyno low 300s hp and low 500s tq ofcoarse the torque curve looks completely diffrent on a diesel. If the 3.0 HO makes it's way into 3/4 ton trucks and proves reliable I'd probably lean that way if I were to ever step back into a 3/4 ton given all the problems with modern diesels.LOL. It's actually your post that is the half truth since the article did not compare the exact same HD truck with a 5.7. As I said in my post you quoted, with "all else being equal". Things like different gearing, weight and aerodynamics will have a huge impact on 0-60 performance and the typical 2500 weighs about 1500 lbs more than the typical 1500. Do a little research into how much even 50 lbs will impact 0-60 performance and you will be shocked. THINK HARDER.
