2022 Big Horn help!
1500GBofRaM
I am having a problem with the airbag sysem. It says front righ impact sensor is bad. I did change it but still the same thing. Can someone provide me with the wiring digram to test wires for continuity?
Thank you
The code does not tell you the sensor is bad. I will add the wiring for the front impact sensor.
Appreciated sir! I attchached a screenshot of the
Make sure the part number you removed is the same as the one installed.
I will dou
The part number on the old bad sensor is 68284052AA but the dealership said it was superseded by 68606357AA (mopar website says the same thing). But I tried 3 sensors so far and none of them worked. I swapped the left and right sensors to make sure I didn't have a wiring issue, and it now says left sensor instead of right. I am really puzzled.
I will dou
I remember a coworker having that issue. You need the original part# there are some still out there and available. Might be just as easy to go to a salvage yard.
You are absolutely right! Check the attached sceenshot I found googling around. They upgraded the sensor but it's only compatible with the newer ORC. And they left people like me stranded because you cannot get the previous version sensor brand new anywhere. Total BS!
