Heads Up Display
TSGTBARCLAY
Just bought a 2025 Big Horn Edition with the Technology Group, Night Edition, and Big Horn Level 2 Equipment Group but I can not figure out how to get the Posted Speed Limit Sign to display on the HUD. I have set it to Advance, Custom, and Normal and still no posted speed limit sign displays on the window. Can someone please provide some insight on how to turn this feature on.
Posting window sticker to ensure I have that option available.
does it show on the navi map in center console screen?
Now that I read your window sticker I don't think the speed limit indicator is available on your truck because you don't have navigation.
It's not a feature you can turn off and on. The speed limit is available on every HUD setting. However, it does not always show on all roads. If it's showing on your navigation screen, it should appear on the HUD. If I could put the speed limit display on the center cluster I would turn off my HUD completely.
No it doesn’t show on the Nav screen either. Wonder what’s missing. It gives me the option to display it in the HUB views but nothing ever displays. Plus, I live in Tucson AZ and have drove down I-10 highway and nothing.
make sure your speed limit display is turned on in the navi. not sure if there's an option for that lol
i drive way too slow to worry about that LOL
It has the standard Tom Tom Navigation as a part of the 12 in infotainment system tho.
Hmm interesting i have this same issue. was searching around to see if others had this issue and if there was a fix. the only things that reliably show on the display is the speed, lane assist, and gear. things like gps directions and speed limits dont show. i can sometimes get it to show if i play with the setup switching from simple/and custom and moving it around it will show for a little bit then go away. oddly it will flicker for what seems like milliseconds when it isnt showing.
seeing as searching has indicated this is a software issue i wont bother taking it to the dealer for now. hopefully a update will fix it.
i had 2 cars with HUD. used it a little at first then the novelty wore off i found it to be distracting.
I believe you need the "Advanced Safety Group II"
got it working. it was indeed just an update. my uconnect was stuck on 31.42. i couldnt get it to update, tried uconnects site and it said my truck was updated already, i tried restarting the radio with no luck. a reset of the radio was able to trigger the update notification for 35.26.
35.26 fixed the hud and all options work as expected now.
Thanks for the update. Glad you got it working!
Gonna have to check my uconnect, see if I need to update. Thanks for the info
