2019 Rebel Miles Range is not accurate
carmcanc
I have a 2019 Rebel 5.7 e-torque. I was hit in the back and have had the repair done but along with the the backup camera question I posted earlier the gas gauge vs range till empty is not correct. When I first got it back the range was going up then would go down and range didn’t seem to correlate with the gas gauge. I took it back and the replaced the fuel sending unit in the tank(I think). I got it back but it’s still not correct. I filled the tank which I believe is 26 gallons and the range only went to 273 and if I remember correctly, it used to be Around 315 or so maybe more. If my avg mpg shows 13.5 * 26 gallons it should be a range of 351? Anyone have any thoughts or suggestions for a fix?
Drive it a bit more, the range estimation varies depending on your current mpg, maybe during the repair it had a lot of shorter drives around the shop, etc.
If it doesn't, then I would look for a mechanical or electrical sending issue.
