Hurricane Fuel
Fuel
  • 87
  • 89
  • 91/93
Results are only viewable after voting.
Brahmajoe
The dealer filled up my S.O hurricane with 87 gas. I was curious should I keep using 87 or use 91/93. I’ve always heard it’s better for a high compression turbo engine. Looking to see what others are doing and results.
If it was my truck, I'd run 91/93, because I want the best performance out of it
What do you use your truck for? If you regularly tow or haul with it I'd probably go with 91. If you use it as a daily driver you might be fine with 87.
I'd do what I did with every Hemi I've owned and experiment with different fuel octane ratings.
I’ve towed our camper this summer with 87 octane and no issues. Drives completely fine with 87.
