P0308 Cylinder 8 Misfire Detected
Jako
Borough of Parks
I had my Ram returned September 28th with a new motor. At 100 miles on the motor the code P0308 popped up. It will be going back to the dealership on Monday but in the mean time I am wondering what are the possible causes. Any help appreciated and thank you in advance.
Misfires can stem from a number of things, but generally the diagnosis goes something like this:
1. Coil Pack - moving the coil pack from cylinder 8 to another cylinder, clearing the code and then driving the vehicle will reveal if the misfire follows the cylinder pack to the new cylinder. If it does, the coil pack is most likely the problem and will need to be replaced.
2. Spark Plug - if the coil pack doesn't present as the problem then the next item to look at is the spark plug. The same procedure can be done, swapping the spark plug to another cylinder to see if the misfire follows, but it's usually easier to just swap for a new plug to see if the misfire goes away.
3. Fuel Injector - The easiest test here is to ohm test the injector to see if it has failed, but injector failures can be intermittent so the next step is the same as the others, pull the injector for cylinder 8 and swap it with another cylinder. See if the issue follows the injector.
Beyond those 3 components misfires can be caused by corruption in the ECM causing the electrical system to not signal the injector to activate at the proper time. The lifter failure / cam lobe wear problem can also cause a misfire, but hopefully not on a brand new engine.
Were all of the components new on the engine or did they swap over items like the coils and injectors from the old engine to the new? Cylinder 8 is tucked up under the overhang of the firewall and is where the most heat in the bay gathers so the electrical portions of the injector and coil there take a beating over time.
Thank you very much for the reply. I believe original coils and injectors.
It's warrantee work so I will not be touching anything, wish I could, as it is an hour drive e to the dealership. Leaving the vehicle is not a pleasant idea either.
I've met the mechanic and service manager, both have been at it a long time and I am confident in their service.
I like your perspective on cylinder 8's position.
Thanks again for the fast reply.
I had the #8 injector act up, this was around 80k miles tho, ohme`d out like the rest of them.
I also just went through this at roughly 87,000 miles. Injector ohm tested fine, coil was fine, all spark plugs changed. Misfire would occur intermittently, but mostly at idle and less when the engine was under load. Ended up being the injector. Since installing a new injector I've had no more problems.
I've run into misfires in the past on my Fords and BMWs and it was always the coil, this was the first injector I've had fail on any vehicle.
Update:
Engine light for the cyl 8 misfire came on with 102 miles and went off (reset?) at 145 miles on the new engine.
Note: Light was off after attending 5 o'clock mass. Proof there is a God?
Thanks to all for the advice.
