Stock rear sway bar size? 2019 Ram Rebel
TheWaterman83
Looking to replace my rear sway bar bushings with poly in the rear. Can anyone confirm if the stock bar is indeed 22mm? Thank you.
Anyone? I've read 22mm. Any concrete confirmation?
Well, I ordered them and it appears the bar is 22mm. One person mentioned on the board and was correct.
Stock OEM rear bar is 22mm..a 7/8" bar. Most swap up to a 25mm/1" bar when changing bars.
