Draining the radiator
c3k
I'm a big believer in early fluid changes. Yeah...100,000 mile/10 year coolant interval is what Mopar says. Other than cooling (and preventing freezing and boil over), coolant has sacrificial anode dissolved in it. Like the zinc block on a boat, it prevents the other metal from rotting and corroding. You know, stuff like aluminum and iron, etc. So, I change mine out every 2-3 years (or 4... Shrug.).
The drain plug on these trucks is a plastic "nut". It's more than just a nut. Here's a pic:
That's a spare. I bought 2 spares, in case I broke the installed one. (Plastic nuts and metal tools. Sigh.) I figured I'd be immobilized if I screwed up. A spare was about $8 online. I bought 2. ;)
If you look closely, you'll see a rectangular piece of plastic molded into one of the visible faces on the hex. There are two of these "ears", the other on the opposite face.
Without these ears, a 16mm socket would fit. Well, the ears prevent that. An 18mm would fit over them. Luckily, a 10mm allen socket fits INSIDE the drain nut.
Here's what it looks like, end-on, with the measurements.
Enough of that... FINDING the drain valve is a pain. It's hidden behind (what I think is) the intercooler hose. (<- I didn't look where that big hose came from, but that's my guess as I sit here typing this.)
It's at the driver's side, bottom, of the radiator. There's a little nipple under it. A 5/16" fuel hose fit on that perfectly, so I was able to direct the draining fluid straight into a bucket. Here are some shots of that.
This is from the passenger side, looking up and left. I left the 10mm allen socket installed still, so it'd be easier to tighten it up.
From the driver's side, looking up:
It took maybe 30 minutes for the flow to reduce to just dripping. It completely emptied the reservoir, and I could hear more draining, as well. Obviously, the radiator emptied. I did this cold, so the block and heater core didn't drain. Easier than being scalded. ;)
(Just a shot while it was in the midst of draining. It ended up emptying that tank.)
I refilled the reservoir, and then started the engine. It pulled some coolant and I just kept adding, keeping between MIN and MAX.
I used 50/50 mix. (I buy concentrate, since I hate paying for water. Plus, I can adjust to a higher concentration if I want.)
Here's a picture of some big jugs:
I got out 1 gallon of the ~2 gallon capacity. Good enough. I'll do that every other year. (1/2 of the volume every other year means that at the 10 year point (RAM's timing to swap it out), only 3% (1/32) original would be circulating. Average age of the total fluid at that point would be 1 15/16 years...call it 2 years old. MUCH better than their spec.)
Overall, it was one of the easiest radiator drains I've ever done. Not a drop spilled and the plug didn't fight me at all. There was no round out or over-torqueing sensation. The biggest difficulty is trying to get eyes on the plug. Once you know where it is, you'll have to feel your way to it, but then it's easy street.
Excellent post! Can you share the part number or a link to that plug? As easy as this was for you, can't hurt for many of us '19-'21 owners to get it done...
Highly recommend distilled water, tap water has been shown to cause issues.
I was buying some distilled water at the grocery store, about 4 or 6 gallons. Some for cars, some to drink (this is before all the water bottles became available). The young lady asked about car issues...since it was distilled. (Like you suggested, that's the only type of water I'll add, whether it's cooling system, batteries, or (not as important) washer.) I stated some was for me to drink.
She was alarmed and told me that it is only for vehicles, NOT for drinking. Lol... ;)
Based on pH testing being done by some members on Facebook, I'd recommend doing this much more frequently than every other year. I am draining/refilling mine every 6 months. Acidic coolant will wreak havoc on the EcoD cooling system in particular and is how you end up with EGR cooler leaks. It's very cheap insurance (especially since you buy concentrate like I do). Guys are finding the Mopar coolant does not hold up very long in these engines, and is dipping into acidic territory in ~1 year... not enough to be immediately problematic, but it will cause damage over time. Since the drain/refill procedure doesn't fully flush the system, that is why I'm doing every 6 months. It's quick and easy, so why not?
  • Like
Reactions: c3k
You can pull the bottom radiator hose off to drain it, instead of messing with that plug
That's what I usually do, but between the intercooler (ecodiesel) position and the funky clip on the radiator hose...I balked. ;)
What Mopar part number is the coolant you used? I saw online I’m supposed to use MS.90032 for the 50/50 mix and for the concentrated mix I need MS.12106. Let me know. I appreciate it.
the premixed (already diluted) part # is 68163849AB, cheapest i have seen it is on amazon.
I'm planning for a major overhaul on fluids in September which will be about 30k for me. Since it's the first time I'll judge the intervals from there out, but coolant is not looking to hot already and I've seen some nasty reports of the brake fluid as well, and since I had the tranny replaced, I'm going to check it's levels and likely add a small amount in the process as well as doing the difs/t-case. So that should cover everything!
But I'd really like to get the radiator flushed as well, not just the reservoir, so I'll probably be removing the hose to drain instead, assuming there is no petcock valve on the radiator itself... why would they make it easy for us? I haven't checked yet.
$20 for premixed 50/50 is about right what I've paid for other coolants as well. I think the total capacity is something like 14 quarts.
  • Like
Reactions: c3k
Capacity... Look at page 437 in the owner's manual. It varies from 11.6 quarts (in my EcoDiesel) up to 18.3 for the Hemi.
FWIW, based on feedback above about how the diesel turns the coolant acidic, I'm now planning to do a drain and fill of the coolant once a year (about 10,000 miles).
Thank you. And yea exactly what I'm seeing on the dipstick for the Hemi too. It's clearly acidic and I'd like to avoid rust in my system.
In the middle of draining and refilling my 2019 5.7 liter Ram. Process is very similar to the OP's Diesel. One item to note, you do need to have a spare drain plug handy. I loosened the plug, drained the coolant, but when I went to tighten the plug, it just kept spinning. I removed to find the spiral threads damaged/more or less gone. I assume the plastic was brittle and disintegrated when I attempted to tighten. Luckily I planned for this and knew my Auto Zone carried a replacement. Dorman part 61134. It doesn't have the hex center but can be installed by hand
thanks for the pic! do you know if this would fit my 2022 3.6l v6 ??
Good call! I bought the OEM part and didn't need it, thankfully. Wait, I bought two. Shipping was a bit so why not buy a spare to gather dust LOL.
Anyone been using non-mopar coolant? The Mopar stuff is about 80 bucks a jug where I live, pretty expensive.
