Bits4brains
I replaced my stock manifolds with BK shorty headers last November due to the infamous OEM manifold warp and bolt pop. About a week ago I started hearing a loud ticking and thought I had something lose. After crawling under the truck with a mirror, I found a crack. I called BK and they were under warranty so they sent me new ones, however these were such a hassle to install I did not want to go through it again. I decided to have my stock manifolds milled down and have started to re-install the stock manifolds. Getting these off was worse than installing them. Im glad im not going back with them. Furthermore I dont trust the replacements would be any better in another year. You can see the crack in the mirror on the first pic. Then I took a better pic once I got it off. Ill take a good look at the passenger side once I get it off too. Im so tired of dealing with Hemi's and the exhaust issue! Hopefully my milled OEM manifolds, new gaskets and new bolts will do the trick.
