Hurricane cold start high idle and operating temp questions
az_sst
I took delivery of a '25 quad cab 4x4 with the Hurricane 3.0 two weeks ago and have questions relating to two issues. Firstly, the high idle time with a cold engine seems excessive to me. At relatively warm ambient temps (80'sF), and a cold engine, the engine will idle at 1500 rpm for ~1.5 mins before dropping to 600-700. At slightly cooler ambient temps (60-70's) the high idle at cold start can be as long as 5 mins before dropping down.
The second issue is with the operation of the radiator cooling fan. At highway speeds, or with the AC on, both coolant and oil temps stabilize at 195-200F. At slower speeds and with the AC off the coolant temps approach 220F before the fan kicks on, and it stays on only until the the temps drop slightly to 212-214F where it turns off again, and the cycle repeats. When it does turn on at the higher temps it is not running that fast (not as fast as with the AC on). It seems to me that it should be moving as much air as possible at those temps.
Just looking to other Hurricane owners for their observations and experiences. Are these behaviors normal or is something wrong with my truck? Thanks.
The idle time is consistent with what I have scene on my truck. Honestly, I have not paid much attention to the coolant temp. but I will try to keep an eye on it and let you know.
I'm guess the engineers want the engine temps and catalytic converter temp up quickly to reduce emissions. Maybee?
Well I answered my own question. A review of temperature related threads in the Hemi sections of this site show a lot of descriptions of the same operation if not hotter: fan comes on at ~220F and off at ~210F with AC off, coolant temps run ~205F with the AC on. I'm calling it normal operation for now although I might go with an after-market PWM fan control for towing to lower the temps a bit. It seems the manufacturers like to run these modern engines at temps that make us old-schoolers a little squeamish.
I'd say just leave it. Modern engines run hotter, it's completely fine.
Sent from my SM-S911W using Tapatalk
Wagoneer 3.0 owner here, mine has the same long idle warm up time, however, mine has the hd tow package with upgraded cooling and while towing 6k enclosed trailer my oil or coolant temps never topped 212. Be on the lookout for failing thermostat housings, it's starting to become an issue because they are plastic.
My truck has almost 1000 miles on it and yes high idle at start is crazy and lasts about 1 minute or more.
I looked at temps the other day and was surprised as well it runs around 200-215 from when I looked. oil psi around 20-25 have seen go up when hit throttle.
I will pay more attention over the next few days.
Your thermostat temp range seems to match that of the 5.7L Hemi, except the fan on the Hemi usually doesn't turn on until 230F, and stops at 220F. Looks like the Hurricane is designed to run a little cooler, at least with fan activation.
Modern engines are designed to run hotter for best power and efficiency, at least that's what they say. The days of 180F is long gone, where today running "cool" is about 205-210F.
Has anyone experienced rough cold starts when an engine RPM fluctuates slightly during the first 15-20 seconds? My 2025 Laramie does this every single cold start. None of the cars / trucks I owned ever did that.
Interesting article talking about the temp at which fuel vaporizes being one of the primary reasons for a high idle. Would make sense on a motor boosted so high. Seems like a high idle mod on a diesel.
I got my 2025 with SST 6 cyl even new it would run rough at start up. At 3500 mile I started to get P0300, p0304 to p0306 mis-fire cyl 4-6. It took 2 visit to the dealer, 1st time the CEL went off, I looked at the codes I pulled with OBD2 reader it went away. The 2nd time the same codes showed up & got stored in the permanent codes. The dealer got a TSB for PCM update. The rough idle went away it’s been 2 weeks. Below is the work order / invoice.
The TSB is 18-071-24
Look at post #11 I attached the work order/ invoice
I picked up mine on 24 October. I sent my salesman the TSB listed on this thread and they updated my truck prior to my getting there. Mine high idles on cold start and also high idles at other times too. For example, drove it today, full water/oil temp, stopped at Mcallister's Deli for lunch, went back outside, started it up, and it high idled. At stop lights, at full temp, I put the truck in park and sure enough, high idle at 1200 RPM or so. Weird. On the temps question mine ran 181-187 transmission temps on highway. At 75 MPH it was 181F and didn't move above it. The other day trans temp at 80 MPH sustained was 187F. Oil temps are 190s to 210s I think; same with water temp. Totally normal. My 2012 Audi S4 oil is 220F-235F.
