12 volt Battery swap
Ducatidoc1
I did a swap of the battery yesterday morning. After starting, lost brake lights, and a bunch of lights came on on the dash, including engine fault, traction control, collision warning, ABS, and one other that I dont even know what it is... When searching the forum, they say all will clear after driving. Not so for me, I did over 80 mi's today and the lights are still on on the dash. Thankfully the break lights have returned though.
This is a 21 1500 Laramie e-torque with 25k on the clock, and yes the factory battery was toast at 6.4 volts, hence the replacement.
Your thoughts???
The other light is stability control, and if i use remote start, it starts, but shuts down a minute later.
Help please...
Took me 3 drive cycles (and it sat overnight).
Surprised you were able to get your battery discharged down to 6.4V!!! Mine wouldn't start at 10.5V.
Well its a m onth+ later and all the lights are still there. suggestions????
At this point you have nothing to lose by disconnecting the battery for a half hour or so and then reconnecting. Battery swaps very very rarely cause any real issues.
Also check grounding and for water in the tail lights.
