WildWildWest
2021 1500 Limited with fully loaded regular mirrors. I swapped to fully loaded tow mirrors.
I successfully updated the BCM to reflect tow mirrors, changed the fog light drop out with high beams, and calibrated the cameras. The truck in the surround view even updated the black and white lines the whole way around it instead of just the sides.
I however, cannot get the running lights to work nor the auxiliary trailer light.
In Alfa, under door module, there is a running light option and a rear trailer light option. When I attempt to change these settings to “on” I get an error. “Failed. Conditions not correct or Request sequence error.”
I have attached a photo. Any insight from anyone?
