Fluids
Adrianp89
Tampa Bay, FL
Time to do some maintenance on the truck.
Looking to do brake fluid, transfer case, and front/rear diffs.
What are you guys using? I am a bit confused by the max tow 3.92s. I have 3.92s and limited slip, but no idea on the max tow.
I would focus on the transmission service before any of the ones you listed. As far as max tow, someone correct me if I am wrong, not avail on the 3.92 plus it would have the coolant lines going to it in order to heat it up faster?
edit: was wrong about the max tow axle...
Why would you say transmission? Brakes probably are a must, fits been 5 years but truck only has 37k. A decent amount of towing.
I waited till 80k before servicing the transmission, should have done it lot earlier judging by the condition of the fluid and the amount of clutch "dust" in the pan. And I don`t even do any towing.
