Panoramic Sun Roof Rattles
holtzd
Have a 2023 Limited RAM with the panoramic sunroof and when it's closed it rattles or makes a knocking noise when the the truck flexes. If I tilt it or open all the way the noise goes away. Didn't do it when it was brand new. Can't see anything loose or anything. Any ideas? It's driving me nuts.
It does sound like the weather stripping creaking. What should I lube it with?
I found other conversations about this issue with sunroofs and they suggested buying Krytox by Chemours GPL 205 Grease on Amazon and apply to the rubber seals. It's 30 bucks for .5 ounces. I applied it on all the rubber and it did NOT fix the issue. It didn't change anything and still makes the same sound when the sunroof is closed. 🤬
Im having this issue on my 2024 limited. ive had two other rams with Pano roofs before this with no issue other than a little leak in middle in car wash under high pressure easily fixed. this creaking noise in front when sun roof is closed and SO obnoxious! every turn or bump something rattling rolling around sound from above me. sounds like somethings loose or not attached. im not thrilled about having them taking my headliner off for this... so I ordered a new one in my prep for not wanting truck after. its also making some weird creaks from underneath not liking this covid build one...
Had the same issue. Ram replaced the track after 6 times of them trying to lube and adjust closure. Problem solved.
Re-awakening this thread. Holtzd, did you ever solve this and if so, what was the fix? I have a 2023 limited with this issue and it's driving me insane
not sure if he has but im still having the noise, haven't brought it in though for it haha... im hoping its a simple fix I dont want them ripping stuff out and in...
Agreed. If you want something done right, ya gotta do it yourself.
My nearest dealer will certainly do more harm than good. Had them do a simple wheel balance after I bought mine and they did this to the inside of the rim...
try loosening this screw 1/4 turn.
I tried krytox, dropping headliner, adding foam insulation, etc etc etc.
finally got mine to stop the creaking noise when I loosened this screw slightly
