Front seat main connector pinout needed.
TRusselo
Hi everyone,
I am currently retrofitting 5th gen rebel seats & center console into my 3rd gen ram.
I have been searching https://connectorrepairkit.mopar.com/ for the pinout of the front seats main connector.
I cannot find it, or dont know what it is called....
Any help appreciated
heres the driver connector
Passenger
In Progress:
Hi everyone,
Passenger
In Progress:
Looks like XY420A
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1 F921 PK/YE 0.75 FUSED IGNITION
2 A907 RD/ 0.75 FUSED B(+)
3 F924 PK/YE 0.75 FUSED IGNITION
4 F507 GN/PK 0.75 LEFT FRONT SEAT BACK SUPPLY
5 F922 PK/YE 0.75 FUSED IGNITION
6 F503 OG/PK 0.50 LEFT FRONT SEAT CUSHION SUPPLY
7 P413 OG/GY 0.35 LEFT FRONT HEATED SEAT CUSHION TEMP SENSE
8 P415 OG/VT 0.35 LEFT FRONT HEATED SEAT BACK TEMP SENSE
9 P419 OG/BK 0.50 HEATED SEAT SENSOR RETURN
10 P921 OG/GN 0.35 LEFT FRONT SEAT VENT CONTROL
11 M11 YE/VT 0.35 COURTESY LAMPS DRIVER
12 M5 WH/GN 0.35 AMBIENT LIGHTING CONTROL
13 F944 PK/GN 0.50 FUSED IGNITION
14 D163 WH/DB 0.35 CAN IHS (+)
15 D164 WH/ 0.35 CAN IHS (-)
16 R6 VT/BU 0.35 RIGHT SEAT THORAX SQUIB 1 LINE 2
17 R8 GY/GN 0.35 RIGHT SEAT THORAX SQUIB 1 LINE 1
18 R58 BU/GY 0.35 PASSENGER SEAT BELT SWITCH SENSE
19 R730 BU/BK 0.35 PASSENGER SEAT DETECTION RETURN
20 D13 YE/BU 0.35 CAN C (+)
21 D14 YE/ 0.35 CAN C (-)
22 R264 VT/BU 0.35 PASSENGER SEAT POSITION SENSOR VOLTAGE
23 F919 PK/BG 0.75 FUSED IGNITION SWITCH OUTPUT
25 A949 RD/ 2.0 FUSED B(+)
26 C91 DB/GN 1.5 HEATED STEERING WHEEL FEED
29 C986 GY/DB 1.5 HEATED STEERING WHEEL RETURN
30 Z909 BK/ 2.0 GROUND
XY 420A is correct. Here is the pinout.
Good Luck.
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1F921PK/YE0.75FUSED IGNITION
2A907RD/0.75FUSED B(+)
3F924PK/YE0.75FUSED IGNITION
4F507GN/PK0.75LEFT FRONT SEAT BACK SUPPLY
5F922PK/YE0.75FUSED IGNITION
6F503OG/PK0.50LEFT FRONT SEAT CUSHION SUPPLY
7P413OG/GY0.35LEFT FRONT HEATED SEAT CUSHION TEMP SENSE
8P415OG/VT0.35LEFT FRONT HEATED SEAT BACK TEMP SENSE
9P419OG/BK0.50HEATED SEAT SENSOR RETURN
10P921OG/GN0.35LEFT FRONT SEAT VENT CONTROL
11M11YE/VT0.35COURTESY LAMPS DRIVER
12M5WH/GN0.35AMBIENT LIGHTING CONTROL
13F944PK/GN0.50FUSED IGNITION
14D163WH/DB0.35CAN IHS (+)
15D164WH/0.35CAN IHS (-)
16R6VT/BU0.35RIGHT SEAT THORAX SQUIB 1 LINE 2
17R8GY/GN0.35RIGHT SEAT THORAX SQUIB 1 LINE 1
18R58BU/GY0.35PASSENGER SEAT BELT SWITCH SENSE
19R730BU/BK0.35PASSENGER SEAT DETECTION RETURN
20D13YE/BU0.35CAN C (+)
21D14YE/0.35CAN C (-)
22R264VT/BU0.35PASSENGER SEAT POSITION SENSOR VOLTAGE
23F919PK/BG0.75FUSED IGNITION SWITCH OUTPUT
25A949RD/2.0FUSED B(+)
26C91DB/GN1.5HEATED STEERING WHEEL FEED
29C986GY/DB1.5HEATED STEERING WHEEL RETURN
30Z909BK/2.0GROUND
Good Luck.
Sweet. So thats the driver side connector.
What is the connector for passenger seat?
And I could also use the center console connector pinout too.
Thanks in advance!~
Center Console. Connector XY360A
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
2 A936 RD/ 0.50 FUSED B(+)
3 A207 RD/GN 0.35 FUSED B(+)
4 F982 PK/YE 0.50 FUSED IGNITION SWITCH OUTPUT (RUN-ACC)
5 D403 OG/DB 0.35 LIN BUS CBC 3
6 E12 OG/GY 0.35 PANEL LAMPS DRIVER
7 M27 YE/BU 0.35 READING LAMPS DRIVER
9 D198 WH/ 0.35 CAN IHS (-)
10 D199 WH/GY 0.35 CAN IHS (+)
11 P801 GN/ 1.5 115 VOLT AC LINE 1
12 P805 GN/DB 1.5 115 VOLT AC LINE 3
14 P807 GN/BU 0.35 INVERTER SWITCH SIGNAL
15 X140 GY/OG 0.75 CD CHANGER AUDIO GROUND
16 X40 GY/WH 0.50 CD CHANGER AUDIO RIGHT SIGNAL
17 X41 DG/WH 0.50 CD CHANGER AUDIO LEFT SIGNAL
18 X486 GN/BG 0.35 AUX AUDIO LEFT SIGNAL
19 X487 GN/BU 0.35 AUX AUDIO RIGHT SIGNAL
20 X488 GN/DB 0.35 AUX AUDIO COMMON
21 X489 GN/YE 0.35 AUX AUDIO DEVICE DETECT SIGNAL
22 P802 GN/OG 1.5 115 VOLT AC LINE 2
24 Z912 BK/ 1.5 GROUND
Awesome, but what about the Passenger seat? or is it the same as driver?
Here is the passenger side. XY420A
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
9 P419 OG/BK 0.35 HEATED SEAT SENSOR RETURN
Here is the driver side. XY410A
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1 G13 VT/BU 0.35 ADJUSTABLE PEDALS SENSOR SUPPLY
2 F503 OG/PK 0.50 LEFT FRONT SEAT CUSHION SUPPLY
3 F507 GN/PK 0.75 LEFT FRONT SEAT BACK SUPPLY
4 F919 PK/BG 0.75 FUSED IGNITION SWITCH OUTPUT
5 M11 YE/VT 0.35 COURTESY LAMPS DRIVER
6 M5 WH/GN 0.35 AMBIENT LIGHTING CONTROL
7 P205 GN/WH 0.50 ADJUSTABLE PEDALS MOTOR FORWARD
8 P206 GN/BU 0.50 ADJUSTABLE PEDALS MOTOR REARWARD
9 P28 GN/BN 0.35 SENSOR/SWITCH RETURN
10 P989 BG/GN 0.35 SENSOR/SWITCH RETURN
11 Q102 OG/BU 0.35 ADJUSTABLE PEDALS SWITCH FORWARD
12 Q103 OG/GN 0.35 ADJUSTABLE PEDALS SWITCH REARWARD
13 P413 OG/GY 0.35 LEFT FRONT HEATED SEAT CUSHION TEMP SENSE
14 P415 OG/VT 0.35 LEFT FRONT HEATED SEAT BACK TEMP SENSE
15 P419 OG/BK 0.35 HEATED SEAT SENSOR RETURN
16 P921 OG/GN 0.35 LEFT FRONT SEAT VENT CONTROL
17 D165 WH/BU 0.35 CAN IHS (+)
18 D166 WH/ 0.35 CAN IHS (-)
19 R263 BU/VT 0.35 DRIVER SEAT POSITION SENSOR VOLTAGE
20 R57 GN/GY 0.35 DRIVER SEAT BELT BUCKLE SWITCH SENSE
21 R729 GN/BK 0.35 DRIVER SEAT DETECTION RETURN
22 R5 BU/VT 0.35 LEFT SEAT THORAX SQUIB 1 LINE 2
23 R7 GN/GY 0.35 LEFT SEAT THORAX SQUIB 1 LINE 1
25 A942 RD/ 1.5 FUSED B(+)
26 A907 RD/ 0.75 FUSED B(+)
Maybe this will help. I made it when I swapped power, heated, vented seats into my 2022 BH.
Pinout for what? What truck? What year? What Trim? We do have a search function you know.
2019 ram 1500 limited seats heating elements.
I'm looking at the heated seat pad (4 wire) for the front. Bk, rd, bk/rd, yellow. Any idea on what goes to what? Thinking black, red, power- yellow is thermostat, then left with bk,rd. (Maybe a return)
Back seat is same thing just different colors x2 back rest and seat. Trying to get a kit to bypass the the computer. I pulled them from my wrecked truck and using in my 3rd gen. All the aftermarket heated seat kits come 2 wire top 2 wire bottom built in thermostat. Any help is greatly appreciated. I've been scanning forums for days with not much luck even reached out to gentherm to see what they say on the 4 wire pinout.
Have you considered AlldataDiy?
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
9P419OG/BK0.35HEATED SEAT SENSOR RETURN
30Z909BK/2.0GROUND
Pin​
Circuit​
Wire Color​
Gauge/Size​
Function​
Option​
1G13VT/BU0.35ADJUSTABLE PEDALS SENSOR SUPPLY
2F503OG/PK0.50LEFT FRONT SEAT CUSHION SUPPLY
3F507GN/PK0.75LEFT FRONT SEAT BACK SUPPLY
4F919PK/BG0.75FUSED IGNITION SWITCH OUTPUT
5M11YE/VT0.35COURTESY LAMPS DRIVER
6M5WH/GN0.35AMBIENT LIGHTING CONTROL
7P205GN/WH0.50ADJUSTABLE PEDALS MOTOR FORWARD
8P206GN/BU0.50ADJUSTABLE PEDALS MOTOR REARWARD
9P28GN/BN0.35SENSOR/SWITCH RETURN
10P989BG/GN0.35SENSOR/SWITCH RETURN
11Q102OG/BU0.35ADJUSTABLE PEDALS SWITCH FORWARD
12Q103OG/GN0.35ADJUSTABLE PEDALS SWITCH REARWARD
13P413OG/GY0.35LEFT FRONT HEATED SEAT CUSHION TEMP SENSE
14P415OG/VT0.35LEFT FRONT HEATED SEAT BACK TEMP SENSE
15P419OG/BK0.35HEATED SEAT SENSOR RETURN
16P921OG/GN0.35LEFT FRONT SEAT VENT CONTROL
17D165WH/BU0.35CAN IHS (+)
18D166WH/0.35CAN IHS (-)
19R263BU/VT0.35DRIVER SEAT POSITION SENSOR VOLTAGE
20R57GN/GY0.35DRIVER SEAT BELT BUCKLE SWITCH SENSE
21R729GN/BK0.35DRIVER SEAT DETECTION RETURN
22R5BU/VT0.35LEFT SEAT THORAX SQUIB 1 LINE 2
23R7GN/GY0.35LEFT SEAT THORAX SQUIB 1 LINE 1
25A942RD/1.5FUSED B(+)
26A907RD/0.75FUSED B(+)
30Z909BK/2.0GROUND
Hey! Just saw a post for rebel seats wiring.
Maybe u could help me….. looking to power up the seats for adjusting them…..and hook up my heated seats …I will run a relay and switch
I’m putting them in an old truck
