Rebel has Delrin ower rear shock bushing !?!
2020 Rebel
I'm in the process of putting on rear airbags and at a stopping point to clarify some tech issues with the manufacturer. Anyway happened to look at my lower rear shock bushing and see that it's Delrin, or some kind of solid plastic, and not rubber which is what I would think come on these lower end shocks!? Anyone know if this is standard on all 5th gen Ram Rebel lower rear shock eyes? Also searched for number from the sticker on the same shock and cannot find it on the internet??
Delrin is like machinable nylon. Stiffer than polyurethane, but still has a little bit of shock absorption. It's used a lot on track-oriented vehicles. Durable, self-lubricating, long-lasting stuff. Unless fire or nasty chemicals happen, those bushings should still be fine when the rest of the truck has long since rusted away.
Bilstein is a lower end shock?
Those are built by Bilstein specifically for Mopar and unfortunately not available anywhere else. Mopar must have spec'ed a different material than standard for the bushings.
I just purchased a set for the front and they did not come with any hardware or dampeners so I have to assume all the little parts are available separately from Mopar.
The pictures show it with dampeners but does not specify the material. The current part number is 68313613AF.
I'm more interested in the issues on the air bag installation.
I can't find the bushing separately in any diagrams. Looking on Ebay at used OEM Rebel shocks you can see the bushing on those. It appears the same on the previous generation Rebels so they must have been using them for a while.
You know about issues going on with my airbag installation?... I did not go with a full Firestone kit. The kit I went with has Firestone bags that are not like the rollover thin bag you get with the Firestone kit that was questionable on a ram Rebel from Firestone, but four wheel parts wholesalers swears it fits. Didn't go with that kit . This kit has much beefier Firestone bags. But I am dealing with piston fitment issues that "Engineers" can't seem to figure out right now.
Ha, yeah, you kinda mentioned them in your first post...
Can you link a pic to the ones you selected and maybe elaborate on what kind of issues you are having?
Edit: I made the assumption you are talking about Firestone helper bags but realize now that you may doing an actual air suspension conversion?.?.?
