jerryr0000
- Sep 25, 2022
why does ram only offer 4 wd in the upper trims
Where did you get that info? Ram offers 4WD in all trucks and trimswhy does ram only offer 4 wd in the upper trims
Actually he's right. You can currently only choose 2 or 4 wheel drive in lower trim levels. Laramie is the highest trim level that has 2wd. Higher trim levels only get 4wd.Where did you get that info? Ram offers 4WD in all trucks and trims
Thanks for clarifying. I misread it.He's asking why you can't get 2wd in upper trims. The Warlock, Limited, Limited Longhorn and Tungsten are only available in 4WD.
Got it, thanksActually he's right. You can currently only choose 2 or 4 wheel drive in lower trim levels. Laramie is the highest trim level that has 2wd. Higher trim levels only get 4wd.
