'24 Ram Hemi less power than '17 Hemi?
Again…. Math is one thing.
Variables is another.
One is worthless without having the other.
Throwing out more math without having the proper variable, like tire diameter, is just more incorrect information.
You are assuming tire diameter is 32” for both size rims/tires.
Clearly, it’s not. More data using that same variable clearly, isn’t correct.
Respectfully silver, you can’t tell me the difference if the variables aren’t correct.
I double checked and I was using 7th gear for comparisons in both trucks instead of 8th. That's my bad. Here are updated numbers, also using as much accurate information as I can find WRT tire sizes and transmission ratios.
TL;DR: you got pretty close to nailing the actual RPMs in both trucks, but being a little bit off in spots means the difference in RPMs between the 2 trucks is less than you think.
Tire sizes:
new truck: 285/45/22 = 32.1
old truck: 275/60/20 = 33
Transmission ratios (8th gear)
new truck: 0.64
old truck: 0.67
Axle ratios
new truck: 3.21
old truck: 3.92
new truck at 65 mph:
= (65 * 3.21 * 0.64 * 336) / 32.1
= 1397
old truck at 65 mph:
= (65 * 3.92 * 0.67 * 336) / 33
= 1738
Difference at 65 mph = 340
Difference at 70 mph = 366
Difference at 80 mph = 419
RPMs at 65 mph
new truck = 1397
old truck = 1738
RPMs at 80 mph
new truck = 1720
old truck = 2139
As mentioned, it's not that it has less power, it's that other variables such as gear ratios, weight, transmission or throttle tuning, are the reasons why the truck is actually slower than your older one.
RPMs at 80 mph
new truck = 1720
old truck = 2139
That’s realistically a lot closer now that we’re in 8th gear….
I was less focused on the math, more focused on the actual RPM…and what you were putting out before simply wasn’t close.
8th gear math.. close enough, splitting hairs afterwards.
I think new truck is a tad low…I know it’s higher than 1720. There’s a mark every 250 RPM.
It’s between 1750 and 2K, and being frank, it’s a tick over the halfway between point.
Frankly, splitting hairs… but we’re playing the same game.
Haven’t seen the OP report back gear ratio or anything else, hopefully didn’t scare him off…
There is another thread on this issue and many have noticed the same thing. My 23 does not have nearly the same pep as my 2012 or my 2017. It's much closer to the 2003 Ram I had when the Hemi was only rated at about 345 HP.
My two 4th Gens were quite a bit faster. At least 1 second 0-60. Both were heavier Laramie’s with 6’4” boxes, fiberglass toppers and all 3 including my current Bighorn came with 3.21’s. My Bighorn with 5’7” box and no topper is much lighter. Transmission is exactly the same in all three cases. Throttle tuning is the only thing that makes sense. It’s been mostly poor on my 2022 since new. Like I mentioned earlier I just learned to live with it.
I’ll go against the grain… previous Ram 2018 Sport with 20” wheels and 3.92 gears, current Ram 2022 Rebel 18” wheels with heavy 33” duratracs and 3.92 gears and my 22 Rebel seemed quicker from a dig and in highway passing.
Wheels are generally heavier than tires, so that's probably a wash.
Gramps storytime... Back in the late 90's I was getting my old workhorse 77 GMC 1 ton 400 rebuilt. The mechanic loaned me his 1996 C1500 shop truck, stock 350 and 350 turbo trans. No idea of gear ratio but the truck was bone stock.
That thing absolutely flew. Felt like triple the hp/speed/torque compared to my 400 ci, 4.10 axle 3 speed auto propane powered (appx 80% power of gas) pig. When I returned his truck I remarked about the phenominal power it had. He told me that he thought the same and said "in some engines everything just comes together". Now a builder would likely take issue with that statement but this guy raced and was a top mechanic, and that's what he said.
His engine stock specced at 255 hp, 330 tq at the crank. My dog 400 was appx 175 hp/290 tq, with a crappy 8.5 compression ratio. Plus my truck weighed maybe 1.5K more due to being a 4x crew cab 1 ton and his was a 2x shortbed std cab 1/2 ton.
Kinda' wish I had bought it off him but a standard cab 1/2 ton wasn't going to carry my family and pull the 28' TT.
My 95 Wrangler with less then 200hp feels like it has a faster launch then my Ram does. But trust me it def doesn't lol. My 18 ram i had before this one felt slower then my 21 does and the 18 was on the factory tires w/ 3.21 gears and my 21 has 35's F load range that are heavy as f**k w/ 3.92 gears. With out you taking them to the track and running them against the clock it's all in your head about what's "faster". And speaking of fast, going 60mph in my stock 54 Plymouth feels like I'm doing 95+mph in my truck. lol
My wife drives our 2014, while I have a 2020. Both Hemi, 8-speed, 3.92. Stock wheels are 20" on the 2014, and 22" on the 2020, but I currently have 18" rims on the 2020. 2020 has E-torque, while the 2014 obviously doesn't. 2014 is a few hundred pounds lighter. 235,000 miles on the 2014, 155,000 on the 2020.
I don't drive the 2014 very often anymore (it used to be my daily driver), but when I do I immediately feel it accelerates faster. My wife notices the same when she drives the 2020: it feels slower to accelerate.
I bought a '24 1500 with the etorque Hemi. I had a '17 with the Hemi. In my old truck, when you accelerate hard from a stop or passing, it has major power. My new truck really doesn't. It's all suppose to be the same. What's the deal with this?
I noticed the same thing, my 16 with 3.21s was noticeably quicker than my 23 e torque with 3.92s. A few things that I think contribute to that.
1- the transmission being different. I think the hp70 was geared better than the 75 which will result in the truck being quicker. And 2- supposedly they did something with the throttle response in the newer trucks which severely hundered sensetivity with major delays. Those things mixed I think is the reason why.
The throttle lag in the newer trucks is bad. I have a non etorque with 3.92 and 34” tires and the delay off the line was ridiculous. Adding a Banks peddle Monster made a world of difference. Now my only worry is peeling out when the light turns green lol.
I had a 2017 crew and currently a 2020 crew. Both have 3.21 gears. The 17 had a limited slip. The 2020 may be a tad slower feeling... hard to tell. Apples to apples, the DT weighs a little bit more in the same configuration.
