Is there a way to move trailer brake settings from being buried in the settings in the settings menu to the Apps menu pages?
BlueHemi1500
Richmond Va
All,
I just installed the Mopar integrated trailer brake controller and programmed using my AlphaOBD. As the title/question asks can this be done to move the trailer settings from the settings menu to the Apps menu? It would be easier for me to set my trailer by hitting the Apps button vs. Apps then selecting settings then trailer settings. (First-world problems :) )
Thanks in advance for your solutions/ideas. FYI I have the PR40.1 version of the software installed and running.
BlueHemi1500
All,
BlueHemi1500
No, not possible.
On mine, if I change gain it pops up in the EVIC, so at least the most common adjustment doesn't require fiddling with the menus.
All,
BlueHemi1500
just scroll in reverse
I think I've got my settings right, but the documentation leaves a lot to be desired. Right now I have the gain set to 6 for a 3,000 lbs trailer. But was confused about the difference between light and heavy electric brakes...
