5.7 with eTorque Inverter Question
Rob517
Hi all,
I have a 2021 Big Horn 5.7 with eTorque and as I understand it, that means no traditional alternator. I want to safely run a 12v pure sine inverter to run a small load of around a 400-500w AC output. Rough calculations show this to be around a 33-44A current draw on top of any other loads that the truck will be utilizing. Can the eTorque system support this load at engine IDLE? I can't find the idle output amperage of the eTorque system on the Googles.
Thanks all.
Hi all,
Thanks all.
I had same concerns but spouse requires a 500 watt oxygen concentrator. I installed a 3000 watt peak 1500 watt continuous inverter. Took a trip . Everything was fine for 90 miles then dash warning light came on "start stop inoperable " "dealer service required." Took to dealership and was told can't install an inverter. $1500.00 to repair! I left upset because I couldn't afford the cost right away. On the way home dash warning light went out and 12v battery was charging 14.1v again. Be careful.
