Ball joints 2020 ram 1500 bighorn 4wd night edition
mitch0703
Does anybody know if I can buy new ball joints for upper and lower control arms , I've tried looking and all I keep seeing is buy the whole thing lca and uca is this true you can't cross reference ball joints , they forcing you to buy the whole arms with ball joints in them. Does anybody know . It's all stock no lifts .
Look at Mevotech Supreme or their HD TTX version. Lowers MIGHT be able to be replaced, but uppers are not. It's also easier to replace full arms, then pop out joint and press new. Also, then you'll have all new bushings as well.
The ball joints on the Ram are not serviceable. The lower can be but could easily turn into a hack job. If you want to save a few bucks, get the Mopar Lift upper control arms (68323530AA, 68323531AA). For some reason they are half the price of the standard control arm. Only difference is the ball joint has a wider range of motion
2019 ram 1500 Laramie new body style. Just last week I replaced my lower ball joints on factory control arms. Bought same year but for a classic ball joints. After being told they didn’t make them for that truck for weeks I decided to just try it with parts for classic, I’m here to tell you it works just fine. Press the old ones out and the new ones in put everything back together then you’re ready to ride.
2020 RAM 1500 Bighorn
Well? So has anyone replaced the lower ball joint? Tell me the part number please!!! Moog or Mevotech?
will they fit a 22?
I would grab the complete LCA. Mevotech makes a HD TTX version. That's what I'll be doing. This way new bushings and BJ. I'll be around 90K miles and doing my lift.
Correct. Personally I wouldn't waste my money on stamped OEM plastic filled UCA. I would grab RC or another brand. That's just me.
these mopars listed are stamped? how much difference from OEMs that came on the truck?
They are stamped steel with plastic reinforcement like OEM. I noticed I left out the "steel" part. Just in case you didn't know. Doing 2 things at once while at work.
big price difference than the RCs as long as they get the job done
