HURRY! Diode Dynamics SS3 fog light kits ON SALE NOW!
gomango392
NY
Don't miss out on Diode Dynamics summer sale!
Save $76 bucks on the SS3 Pro fog light kit! Also use code Gomango392 for free shipping on your order, on top of the 20% off! The sale ends July 8th but the code is always good for free shipping 😁 SS3 LED Fog Light Kit for 2019-2024 Ram 1500 (non-LED)
Converting oem LED to factory halogen to run the SS3s is easy!
20% off for this kit? :)
Stage Series Fog Pocket Kit For 2019-2024 Ram 1500​
Yes! Pro and max series!
Edit: ope my bad, I just realized you were asking about the ssc2 kit. So what I would advise doing is just buying the bracket kit for our trucks and then order the pro series SSC2s sperately. That's one workaround since the sale is only for the pro and max series lights.
I actually had that exact setup in my cart but am second guessing the sport vs pro. For on road use only, it seems the sport is better due to tighter beam pattern. Thoughts?
I'm also going back and forth between white and yellow. We get very little fog but snow and poor driving conditions on and off from Nov to March. Has anyone combined them? I was thinking yellow on the inside and white on the outside for ditch lights to watch for deer.
There can be, just add 4 pro series SSC2s to your cart and then add the "bracket only" kit to your cart! You'll get the 20% off that way. But personally, the ss3 pro gives better output which is why I went with that over the 4 ssc2's. Jeremy at Retro Shop also confirmed that the output is better with a single SS3 vs 2 SSC2's! A little more work since you have to switch out the brackets and bezels but it's easy to do and worth it!
Definitely go pro! Especially if you get the SSC2 kit. Huge difference in output between those BUT the SS3 will perform better than 4 SSC2 pros which is why I did the oem LED to halogen fog conversion. But back to your original question, I ran the SS3 sport fog kit (which has a tighter pattern than the pro) and upgraded to the pros, I did not notice any difference when out on the road with the less tighter beam pattern from the pros. And as far as color goes, another plus to going with the SS3 kit is if you wanted to change output color, it's much easier to do only having to change 2 lenses instead of 4. I actually switch to amber for winter time and it really does make a big difference! However if you go with the SSC2, you coukd always order 2 amber and 2 white 😁 and go with a sae fog on one and a combo on the other. Plenty of options!
