kaedenr
- Apr 10, 2023
Hey everyone. Just purchased a 2019 RAM 1500 Limited with Air Suspension and now running into an issue where the battery is dying overnight. This didn't seem to be an issue the first couple-few days I had the truck. It'd start just fine every morning, however since putting a leveling kit on, this seems to be a consistent issue (coincidence maybe?). I installed a 2" leveling kit a couple of days ago and now both mornings since then, the battery has been dead when I go out to leave for work in the morning. It's also worth mentioning that I now occasionally get a "Service Air Suspension" message on the dash that goes away on it's own almost as quickly as it comes on. This happens probably 2-3 times a day, but I drive a lot. (Thinking separate issue, something to do with calibration maybe after the level kit?). Either way, really just wondering if there's any common battery draw type concerns with these trucks before I end up taking it to the dealer for the issue. Thanks in advance!
--UPDATE-- 7/1/24
It is DEFINITELY Related to Air Ride. Set truck to "tire jack" mode overnight this weekend to in theory disable auto leveling even with key off, and truck started up just fine both mornings afterwards. Also got the chance to do some digging on the "Service Suspension" message that's coming on and off and found it's setting codes for RF and LF Ride Height Sensor stuck. Anyone else ran into this after a level? Thinking about putting the factory sensor links back on to see if that changes anything
--UPDATE-- 7/1/24
