2021 ram 1500 rear running lights and taillights not working
cheesehead ram
2021 Ram 1500 3.6L rear running lights nor the taillights are working. The Brake lights work, and the hazards and turn signals work. I have pulled the battery for 5 minutes, no change. I tested the trailer portion, and it all works fine.
There are no fuses to speak of for these items, I am assuming it’s a module or something along those lines.
Love to hear what else I can do.
You haven't said what trim you have. There are different taillights, bulb or LED.
The items are factory originals, the taillights, and the running lights all went out at the same time, however, the blinker and hazards both work. This rules out bad running lights.
You ever fix it? Having same issue same year and trim.
my left taillight cuts off after starting the engine... blinks 4 times and then cuts off.... comes back on every time i restart it!!! it stays on as long as i don't start it???? has anyone had this problem?????"
I'd suggest starting your own thread instead of hijacking someone else's. Do you know if it is LED or a bulb? Might add add that to your new thread.
