Auxiliary Switch Kit - Mopar (82216449AC)
nickman
I'm wanting to install the OEM auxiliary switch kit. It includes the power distribution center, harness, and switch bank. Does anybody have experience ordering this? I am wanting to make sure that the existing equipment button labels come configured for my truck, Traction Control, Tow/Haul, Park Sense Rear, and Park Sense Front. I think there are multiple configurations for this depending on what the truck is equipped with. I emailed the seller, moparoempartsoutlet.com, they said that this information is not specified within their dealer catalog. Does anybody know if the buttons come configured for my truck based on the VIN number when I order?
Link to part---https://www.moparoempartsoutlet.com/parts/mopar-auxiliary-switch-kit-82216449ac
2022 1500 Big Horn Built to Serve Edition
Possible info here
Did you find the answer to your question? I am facing the same issue and I am curious to how if worked out for you.
2022 1500 Big Horn Built to Serve EditionI
I used these parts - 68578990AA - My 21’ has tow/haul, traction control on/off, rear and front parksense.
82216449AC will work as well. I used that same kit. The buttons that came with this kit was NOT the correct one. I believe this kit is for a TRX, but will work for the 1500’s just the same. You just to have to find a solution to mount the PDC. I just bolted it to the front of the fuse box I believe.
