Greetings all,
So trying to see what the real world max will be for towing with the V6 Pentastar... With the 3.55§its rated at around 7700, so if gather realnex ld would be a comfortable max of around 5500 lbs. 6800 on the 3.21, so probs around 5000 lbs. I really need the better mpg, even if it is only 3 or 4 mpg as I put on plenty of miles for work (don't hall anything except people & occasional home materials). Íbamos like that the V6's have the highest payload ratings. Will tow a 5000-5500 lb (that's GVWR btw, not dry weight, with tongue at around 800 lbs loaded) RV camper trailer 4-6 times a year.
That's said, anyone here tow any RV's in the 5000-6000 lbs range? This towing will mostly be on the flats and warm weather of Florida.
