Mopar oil filter for 2022 5.7 Hemi
Dewey
WI
What Mopar oil filter are you guys using for the 2022 Hemi eTorque?
Don’t have my owners manual handy but looking online I’m seeing multiple numbers.
4892339AA
4892339AB
I’m guessing same filter since I used the AA on my last truck except maybe a minor change was made affecting the part number.🤔
Wanna make sure before I order a bunch of them. Thanks
I believe there is also an AC version, which has an 8 micron filter, but any MO339 will be fine, I think as you mentioned the AB is the most recent version.
I got my most recent one at Walmart for $10. The website stated they didn't carry it, but my store had tons in stock, cheaper than most online pricing if you include shipping. You may want to start there.
That's where I get mine.
I did a search and found a couple oil filters from mopar but unsure which one is correct I see a 339 and 899
The correct one is the MO339, which is available at Walmart, just got one for $10 or so.
The 899 is a bit larger, but people have made it fit in those tight confines we have on our trucks. I will tell you, I do oil analysis with every one of my oil changes and the smaller 339 has shown to have great filtering performance.
The other filter is likely for better flow. They should filter the same if not very close.
Neither one is wrong, or bad.
I've been using Fram filters in all my vehicles for 50 years and never had an oil related issue. The one I use for my Ram truck is Fram ultra synthetic XG 10060. 8 bucks at Walmart. It fits perfectly and has the Fram sure grip which makes it much easier to screw on and off especially if you have a little oil on your hands.
