New Ram 1500 with super LOW battery voltage?
island1
Hi everyone, I picked up the new 2024 Big Horn last week. It's my first truck. Last night the battery died while driving. I ended up calling AAA for a jump start. What should I do now? Any suggestion? Thank you.
Brand new 2024 with less than 500 miles on it? Back to the dealer. Let them sort it out under warranty.
Agreed. Why would there be any other suggestions if it's brand new?
I can see a battery needing to charge if it's been sitting on the lot for a while. Though if it died WHILE you were driving, most likely a bad battery. I've never even heard of that happening.
Thanks for the reply!
Just got back from the dealer, and they said "After running the maximum battery tester for over an hour the battery came back good."
Uggh. I wouldn’t be happy with that comment. What did they say about it dying WHILE RUNNING THE TRUCK??
Faulty alternator? If not, I’d want a new battery.
My 48 volt generator quit on me with 3700 miles on the clock. Vehicle dies on the way to the dealer. Hauled it in and they quickly figured out what was wrong. They said they kept 2 generators on hand so it's not an anomaly when one craps out. I called FCA Roadside Assistance about getting something to drive and they said to call back in 24 hours. The guy I talked to in India apologized repeatedly but that wasn't what I needed. So I called the next day and got a female relative of his and I told her what I thought of their Roadside Assistance. A few days later I got an email survey about my experience with FCA Roadside Assistance...I filled it out from the best of my recollection.
Hmmm, I'd be (and am) a little suspicious of that diagnosis given the information we have.
What's it reading as you drive now that they charged the battery?
Do you have the etorque?
I had the v-6 with e torque and it would do this after the random shut off / stalls.
After 4 trips to the dealer and trying to get a head engineer involved, they discoverd the e torque unit to be faulty. No issues since it was replaced.
2023 v6 with e torque.
because it aint got gas in it!!!
jokes aside what above guys said.
No way I would take that answer. Dealer is blowing you off. gen/ alternators are either good or bad and yours is obviously bad.
You mean the generator?
It's dying while the truck is driving, even a typical bad battery should not allow the truck to die while it's running.
Yes that’s what I meant got so discouraged thinking about the dealers answer I didn’t watch what I was typing. Run away thumbs again 🥺
I also carried my multimeter and would test the battery when my screen would show this and the battery would be at 13 volts or better.
Check the generator (Etorque unit).
No issues in the five days since then. Battery Voltage is between 12.7v - 14v. But yes I am a little suspicious of what they said (after reading the above comments)
Yes it's 2024 v8 with e torque
I guess that s what they call "infant mortality ". Just bad right from the start.
We got to hope it wasn't a bad run of them.
  • RHO
