Joemama88
What is factory option?Plenty of options out there. But I've always seen issues with aftermarket weather it is fit and finish or quality. I have the factory option on my BH. That's what I would go with.
He has a Silverado, but I would think the RAM would fit. Lasfit is a sponsor of this forum. Maybe hit them up to confirm.did they fit with OEM cover back on?
I did. He said they are not tested yet. Actually got a little argumentative with me on the phone. The first time I called today they guy said NOTHING about them OEM dust covers not being able to work. Then he said the different in the LCair LC plus is they have built in resistors. Something the other guy left out. Why would a Silverado guy be one a Ram forum?He has a Silverado, but I would think the RAM would fit. Lasfit is a sponsor of this forum. Maybe hit them up to confirm.
Where is a Silverado guy? Me? Dude read before you respond.Why would a Silverado guy be one a Ram forum?
You said He was not talking about you. I did not know you were talking about.Where is a Silverado guy? Me? Dude read before you respond.
BHs have an option for the Laramie LED lights.What is factory option?
I have no damn clue what you are talking about. Unless someone has responded to me on here that I have blocked and can't see their responseYou said He was not talking about you. I did not know you were talking about.
OH you are talking about the whole housing? What is BHsBHs have an option for the Laramie LED lights.
There has to be someone who has a 2024 I would thing there is no difference between 2024 and 2023 Halogen head lights. Now back to square one.I have no damn clue what you are talking about. Unless someone has responded to me on here that I have blocked and can't see their response![]()
BH = Big HornOH you are talking about the whole housing? What is BHs
You are talking about the whole housing I am assuming. Wasn't trying to spend that much.BH = Big Horn
You must has the LCair if it has internal resistorsNo. They come with an internal resistor. True plug and play.
I have been on the phone with them 4 times today the air are the only one with built in resistors. But said the ones you have, have enough power and don’t throw an error on the rams.
Sweet I ordered all of them besides the high beams. Did you get the DRLs that turn orange when blinker is engaged. Can’t remember what they were called.Sounds about right. I can confirm that I have zero flicker with the head lamps, and I have zero issues with all the other LED’s (turns, stops, etc).
I have both types of @LASFIT turn signals. I ran the switchbacks for a while. They are white when parking lights are on and blink amber when turn signal is engaged. I just recently put the all amber’s back in just to change the look up a little bit.Sweet I ordered all of them besides the high beams. Did you get the DRLs that turn orange when blinker is engaged. Can’t remember what they were called.
Me too. I was very patient and went slow and I have small hands. Went by feel mostly. I still had large bruises on each of my forearms develop afterwards. Totally worth it.I swapped the halogen bulbs for Lasfit bulbs, it took a little time, not too hard. I followed their directions from youtube on how to change the Low beams, fog lights and high beams. Hardest part was getting the low beams in, one arm through the fender well and the other arm in from the top. It was like an extended hug on both fenders.
Just make sure you set the pigtail in the right orientation the first time so you don't have to reach back in and adjust, oh, and before installing plug them in and make sure they are plugged in correctly and come on so you don't have to take them out and do it again. Good luck
