2022 Ram 1500 3.5" RC lift
Goodyear, AZ
Just installed the RC 3.5" lift w/monotube shock and strut upgrade. Very happy with it. After a week of driving shook off a little stiffness, it rides just right. Since I posted about the lift, I thought I'd share some other things I've done as well. Comments and criticism equally welcome!
2022 Ram 1500 Big Horn Night Edition (white on black). Rough Country 3.5" lift w/coil overs and monotube struts and shocks. Black Fuel Rebel 22x10 wheels, 35x12.50R22 Hercules TIS Offroad TT1 M/T tires. Magnaflow direct fit muffler, 5" Carven black exhaust tips, Phoenix Audio 13.6" vertical screen head unit, JBL 6x9 F/R doors speakers, Infinity Kappa 3.5" dash, Infinity Kappa 2" rear door, Kicker 2400W mono sub amp, Kicker 1800x4 amp, 2xSundown Audio SA10-D4 subs wired parallel for 1ohm load, down firing 34hz vented enclosure, led lights inside and out, Katskin leather interior, Pedal Commander, Havoc HS2 Black Hoop side steps, Truxedo Pro X15 bed cover, spray-in bedliner, tinted windows (35% Front, 20% Rear).
Wow! Thats a great set up, inside and out. You did it right!!
The Katskin looks perfect! Also love the lift, wheel, tire combo
Great aesthetic for a rugged truck man!
Thanks for the compliment! And I can say other mounting the tires on the rims, I have done everything myself. There's a certain satisfaction doing some of the typically farmed out jobs, like the suspension lift, myself instead of a shop. Of course, saving the $$ doesn't hurt:) I should have taken a couple of snaps of the sub enclosure and amps. I had to get creative mounting the amps as I didn't want them on the back of the cab behind the rear seats. To hard to get to for adjustments. I also have a 5 farad capacitor tucked in there as well.
wanting to do the same but first on the Phoenix head unit how do you like it and did you get direct from Phoenix and how was the install? I have nothing but issues with the 8.4 UC5 and want to get something to make me love my truck again
Very nice looking truck. I’ve got the same lift and wheels on my billet silver truck. Been very happy with it
I have the same color is yours a quad or crew? post some pics
I really like the unit. I bought directly from phoenixautomotiveinc.com. Install was pretty easy. They have a couple of YouTube videos detailing wire connections prior to install. One thing; the connection lable reverse camera does not work for the factory rearview camera. There is another yellow input thats not labeled camera, and that one works fine. It may be that my unit was just mislabeled/: Other than that, this thing does it all, and no lockout while in motion!
How long has it been installed? I have alot of issues with my 8.4 where it will not respond to touch or flashes like crazy or just stays black nearly daily I have to do a reset several times just to get it to work. Its sad as its the main thing I hate about my truck and I want to start loving it again so maybe the Phoenix is the answer
what wheels (offset) and tire size are you using
The same one as the OP wheel wise. 22x10 fuel rebel 6. I think the offset is -18. It sticks out maybe an inch or so. Not as far as it looks in some of those pictures. Tires are 35x12.50 venom power Terra Hunter xt
