Adding Passive Entry: How-to
Quietpeen
Looking for help please. Gearing up to do this mod on my 2021 ram 1500 DT, but its Delmonico Red, with body colored door handles. I only see that color in the HD chart? I'm guessing that the numbers would be as listed for the 1500 except with the "NRV" color code inserted? So then would the numbers be this?
DOOR HANDLES - 6CV64NRVAD
CAP L - 6CV50NRVAC
CAP R - 6CV52NRVAD
Regarding the rear antenna, it seems the "521" part number has both holes on one side while the "560" has holes on opposite sides? Any idea which is a better fit for the 2021 truck?
Also, does the left cap automatically have the keyhole? Any tips on which site has the best pricing? Thank You.
not sure if this helps but the HD part numbers for the door handles will not work on your truck. Maybe you already figured that out but I did not investigate the part numbers you posted. For the rear antenna the number of holes doesn’t matter. There was a part # that worked but was much cheaper when this thread was started. That cost difference might not be a factor anymore. Buy the one that is cheapest and is confirmed to work in this thread. If the holes don‘t match up just drill a new hole in the plastic or come up with a different way to mount it.
mpmaz1
I didn't use the HD part numbers, I added what I believe is the Delmonico red color code to the 1500 part numbers. As for the antennas, I'll have to crawl under there and see where the holes are at. They're both cheap.
l84dnr
Finally got it all done and programmed. Love everything about except the fact that my A.R.E topper doesn’t unlock when using the tailgate release. It gets its signal from the door locks and the doors don’t unlock with the tailgate button but the tailgate unlocks when the doors do. Weird but I can live with it.
ZEW77
A lot of pages on this thread. Sorry if the answer to my questions are listed somewhere and I missed it.
I originally bought all the parts to do this PE install to my granite crystal metallic '19 Bighorn Level 2. I never found the time to install the parts and now I'm trading it in on a granite crystal metallic '24 Bighorn Night Edition Level B on Monday.
I would like to add PE to my '24 and I just need to know if everything in this guide is the same for the '24?
Since my '24 is a Night Edition, it has black door handles. Does anyone know the part number for the PE door handles for a night edition or does anyone know the color code for the black handles? I'm thinking I could paint the crystal granite metallic ones that I bought previously but that would probably cost more than buying the black handles. Thoughts?
Alaskaflyer
Fairbanks, Alaska
Post #2 has the part numbers to most colors.
vincentw56
It should still work fine for a 24. Diamond Crystal is the color and it is in the original posts.
ZEW77
Thank you. I had a feeling it was Diamond crystal black but wanted to double check.
Quietpeen
give Bam a shot. Pretty sure you can process the order without adding your vin and they generally have the best prices.
speedster25
If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
hi jimmy, realizing this thread is a bit old. PM me with availability, and payment options. looking for all thre for my new to me 2021 Bighorn. thanks
