what s this ETC warning light
cerbo
TN
Electronic Throttle Control (ETC) Warning Light
This warning light will illuminate to indicate a problem with the ETC system. If a problem is detected while the vehicle is running, the light will either stay on or flash depending on
the nature of the problem. Cycle the ignition when the vehicle is safely and completely stopped and the trans- mission is placed in the PARK position. The light should turn off. If the light remains on with the vehicle running, your vehicle will usually be drivable; however, see an authorized dealer for service as soon as possible.
It a little red icon showed up brief ly I believe upon start up but went out immediately (more than once).
What is this warning about or is it normal as long as it goes out upon startup ? I had to look up symbol as everything running fine.
