Sealight LED and remote start
Dwells3110
Seeing if anyone may know the answer here.
I put in sealight leds in my truck (adjusted them so they don’t blind anyone). They work perfectly except every once in awhile during remote start the driver side light doesn’t turn on. If I turn my truck off and back on it’ll turn on. Only happens during remote start and only the driver side light but doesn’t happen every time. I Even switched the leds around to see if that was the issue but once again it was the driver side. Any insight would be helpful!
Check your wiring, etc.
Post info on your truck. Year, trim, etc.
Definitely weird only on remote
Maybe the frequency from the remote start is causing it. A bit above my pay grade but I know this was an issue with rear brake light bulbs when we started throwing aftermarket LEDs into these 5th Gen BH's.
