Running High Coolant temp
nlv_gonzalez
I have a 2021 Bighorn 5.7 Hemi, switched out my thermostat to a 180, my coolant temp haves be as up as 246 and my e fan sounds louder then normal, Any ideas why its running extra hot is it normal to run that hot
both temp gauge show normal, it sometimes goes just passed a lil half way but then goes back to running at 230
Curious, why did you switch the thermostat to a 180 in the first place?
Two thoughts:
1) It is possible to put a thermostat in backwards.
2) If you change to a significantly cooler thermostat without also changing the fan temperature setpoints, you may be running with the thermostat wide open and the ECU trying to control temperature with only the fan, which will have a lot more lag and may cause wider temperature swings than the stock thermostat.
Two thoughts:
^^^^^^^^^^^^^ This
OEM is 203 degree tstat
Well stated!
Two thoughts:
Thank you! I’m assuming I can adjust the set points when I have a tune. Just waiting for my unlocked pcm to arrive and I’ll be able to make that adjustment
Did you vac all the air out? Maybe an air pocket? Could also be a bad T-stat. A cooler T-stat would not need new fan temp points. The ECM only does what its told to do. I believe the fan set points are variable and the fans ramp up as the temp increases. Do you still have active shutters? Are they closed?
