Will not crank battery good Flickering dash
Bouldboys5
Hey guys, while trying to start my 2020 ram 1500 bighorn I get a flickering dash and clicking noises from the fuse / relay box under the hood.. Metered the battery and it shows 12.72 volts.. Any suggestions?
Cliff
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Cliff
Put your meter to Min/Max hold.
What does the battery measure under load?
Nascar Tommy
My other Ram is a Dodge.
NW Indiana.
Even if your battery tests good under load or anything else, replace it. It's old enough to be bad.
kapinallinen2
Southern Maryland.
Best under load test is when trying to crank it, this is when the voltage Min/Max hold on the multi-meter comes in handy.
Bouldboys5
Ended up being the battery .. replaced it no issues..when I metered old battery,it appeared good.. A little confused .. Thanks guys Cliff
