I have a 2020 bighorn 5.7 etorque 4x4 crew with the 3.21 gears.  The tow rating listed for my truck is listed around 8100lbs.  The same truck with 3.92 is listed at 11000 lbs.
My question is, couldn't the 3.21 truck just run a gear higher to make up the difference?
		 Step functions generate harmonics and other nasty side effects.
 Step functions generate harmonics and other nasty side effects.  I'd have thought the frame would bend before cracking, but if you hit it repeatedly fatigue may set in. They're cheaper than air bags and don't require a compressor or develop leaks with age, I guess you get what you pay for. As always, caveat emptor.
