Psifer
I've been helping RB Performance Brakes host a couple of group buys over on the TRX forums. Since all the DT 1500s share the same brakes, I figured I would share the information over here too. This is a perfect opportunity to get either brake kit at a group discounted price making the cost marginally more compared to OE rotors and pads replacement. Both kits are great options to help reduce rotational mass and gain back some of the lost performance when going to bigger tires. The 17" kit is the first of its kind for the DT platform opening up a wide area of tire options. The 18" kit is a fantastic option for anyone wanting to retain OE compatibility. The front calipers with the 18" kit are compatible with OE rotors and use the same FMSI pad shape as the Challenger/Charger/SRT8s so plenty of options are available and not just limited to purchasing from RB.
www.ram-trx.com
www.ram-trx.com
RB Performance Brakes 4-Piston BBK For 18" Wheels
Group Buy #2: RB Performance Brakes 4-Piston BBK For 18" Wheels Q2 2024 (OPEN)
Because of the success of our first group buy, Warren has provided us the opportunity for a second group buy to allow anyone else still interested to receive the bulk discount. Just like the first group buy, this will be limited to 10 participants due to the size of the production batch. This...
RB Performance Brakes 4-Piston Downsize Brake Kit For 17" Wheels
Group Buy #3: RB Performance Brakes 4-Piston Downsize Brake Kit For 17" Wheels Q2 2024 (OPEN)
RB Performance Brakes has recently released a 4-piston Brake Kit with 2-piece rotors capable of fitting within 17" wheels. The rear caliper bracket needs to be replaced to a shorter piece, and the rotor size will be downsized to 355mm (from 375) also but OE calipers and ePB are retained so your...
