Would a 2024 Hemi be susceptible to the "Hemi Tick" ?
Ram1500OwnerMaybe
Florida
What percentage of people experience the non-normal issues with the 2024s?
mikeru82
The Palouse
What's your definition of "non-normal"? Ram considers the hemi tick to be normal if it only lasts for a few seconds at initial start up. And a 2024 Hemi would be just as susceptible to it as prior model years because there haven't been any design changes in the last few years to address it.
silver billet
Depends on what "tick" we're talking about. Lifter bleed down (a nasty startup noise that goes away quickly), definitely susceptible. Lifter failure (ticking on hot idle and eventually cam lobe is wiped along with crushed needle bearings), that appears to be less common in recent years after the last lifter update.
mikeru82
The Palouse
For sure, which is why I asked the question to the OP.
Ram1500OwnerMaybe
Florida
The tick which require repair.
Many call the broken manifold leak the "hemi tick" as well
